6593 Discussions
Little problem in text_detection_demo on Windows
ininder__gg
Hi is me again,
Now I'm study importing the openvino on windows,
No sure if it is really a bug or not. In text_detection_demo ,not like other demo, it need user to input the webcam's path
I find some document there and related post here , the document call for the webcam node in "windows" tutorial.
But actually there is no such /dev/video0 in Windows, which make nothing to type for parameter -i
In order to solve this problem ,we have to go to the VideoGrabber::VideoGrabber and edit the path like:
VideoGrabber::VideoGrabber(const std::string &path, bool is_web_cam): cap(stoi(path))
Then we can use the demo on windows as
 .\textDetection.exe -m_td .\text-detection-0003.xml -m_tr .\text-recognition-0012.xml -dt webcam -i 0
In origin program ,
1. You cannot type 0 in -i to launch webcam
2. The program force you to type something in -i
3. The program would find the parameter in -i as path even you set the -dt as webcam
saura
Hello Ininder
Just add this following code to the VideoGrabber function and  in the command prompt give -i cam and -dt webcam.This should work fine. Good luck.
if (path== "cam") {
  bool is_opened = cap.open(0);
} else {
  bool  is_opened = cap.open(path);
Pronina__Kate
Thank you, Saura!!!
