6605 Discussions
Looks like the Caffe layer "Silence" is not supported... is this correct?
Hey Guys,
I am using a deploy.prototxt definition that has a "Silence" layer… as a result, I am seeing the following error with the example environment =>
mdouglas_95136:~/workspace/ncsdk/examples/caffe/GoogLeNet$ make run
making prereqs
(cd ../../data/ilsvrc12; make)
make[1]: Entering directory '/home/user/workspace/ncsdk/examples/data/ilsvrc12'
make[1]: Leaving directory '/home/user/workspace/ncsdk/examples/data/ilsvrc12'
making prototxt
Prototxt file already exists
making caffemodel
caffemodel file already exists
making compile
mvNCCompile -w deploy.caffemodel -s 12 deploy.prototxt
mvNCCompile v02.00, Copyright @ Movidius Ltd 2016
[Warning: 37] Output layer's name (instance_ignore_layer) must match its top (category_score)
[Error 4] Toolkit Error: Stage Type Not Supported: Silence
Anyone know if:
a) this is a legitimate error and "Silence" layer is not supported?
and
b) when is the support coming?
c) if it's in Beta, can I be a Beta tester? :-)
Thanks a bunch!
Mark Douglas
@mdouglas_95136 Hi, in order to help us debug your issue, can you provide a link to your prototxt file? Thanks
Tome! Thanks for asking.
I would need your email address for my SharePoint box.
my email is mark.douglas@nxp.com
@ Tome_at_Intel
so my deploy.prototxt file is just too long and I get errors trying to place it in these postings.
Mark D.
@mdouglas_95136 When typing a comment, there is an option to link a URL or add a file attachment in the forum toolbar above the comment box.
ok thanks @Tome_at_Intel
I need to open another discussion as if you look at the comment here there is no option to add a file… but I can from a "new" discussion.
Mark
Getting "file not allowed" Argh…
when I try and add a file by either dropping in or by browsing. I can only see this option from a "new discussion" and even then it don't work. I tried under PaleMoon, FireFox, Chrome and IE browsers… no different.
So this is working for you guys?
MD
here is a "try" to add the prototxt file that's stumbling on the "Silence" layer
[file:///e:/Movidius/deploy_not_compile.prototxt](file:///e:/Movidius/deploy_not_compile.prototxt "file:///e:/Movidius/deploy_not_compile.prototxt")
sorry… for me this feature is just not usable :-(
@mdouglas_95136, alternatively you can copy paste the entire prototxt file within the Code formatting template (between ` symbol - it'll be on the same key as ~ tilde symbol). Like so:
input: "data" input_shape { dim: 1 dim: 3 dim: 227 dim: 227 }
Thanks @AshwinVijayakumar ; however, same error about content length:
"Body is 3093 characters too long."
it's just too long or too many characters (multi-layered net config)
I may try in pieces
MD
layer {
type: "Input"
top: "data"
input_param {
shape {
dim: 1
dim: 8
dim: 512
dim: 512
layer {
type: "Slice"
bottom: "data"
top: "dump_blob"
top: "mask"
slice_param {
slice_point: 7
axis: 1
layer {
type: "Silence"
bottom: "dump_blob"
layer {
type: "Convolution"
bottom: "data"
top: "conv1_1"
param {
lr_mult: 1.0
decay_mult: 0.0
param {
lr_mult: 1.0
decay_mult: 0.0
convolution_param {
num_output: 48
pad: 1
kernel_size: 3
stride: 2
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "ReLU"
bottom: "conv1_1"
top: "conv1_1"
relu_param {
negative_slope: 0.0
layer {
type: "Convolution"
bottom: "conv1_1"
top: "conv1_2"
param {
lr_mult: 1.0
decay_mult: 0.0
param {
lr_mult: 1.0
decay_mult: 0.0
convolution_param {
num_output: 48
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "ReLU"
bottom: "conv1_2"
top: "conv1_2"
relu_param {
negative_slope: 0.0
layer {
type: "Convolution"
bottom: "conv1_2"
top: "conv2_1"
param {
lr_mult: 1.0
decay_mult: 0.0
param {
lr_mult: 1.0
decay_mult: 0.0
convolution_param {
num_output: 64
pad: 1
kernel_size: 3
stride: 2
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "ReLU"
bottom: "conv2_1"
top: "conv2_1"
relu_param {
negative_slope: 0.0
layer {
type: "Convolution"
bottom: "conv2_1"
top: "conv2_2"
param {
lr_mult: 1.0
decay_mult: 0.0
param {
lr_mult: 1.0
decay_mult: 0.0
convolution_param {
num_output: 64
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "ReLU"
bottom: "conv2_2"
top: "conv2_2"
relu_param {
negative_slope: 0.0
layer {
type: "Convolution"
bottom: "conv2_2"
top: "conv3_1"
param {
lr_mult: 1.0
decay_mult: 0.0
param {
lr_mult: 1.0
decay_mult: 0.0
convolution_param {
num_output: 96
pad: 1
kernel_size: 3
stride: 2
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "ReLU"
bottom: "conv3_1"
top: "conv3_1"
relu_param {
negative_slope: 0.0
layer {
type: "Convolution"
bottom: "conv3_1"
top: "conv4_1"
param {
lr_mult: 1.0
decay_mult: 0.0
param {
lr_mult: 1.0
decay_mult: 0.0
convolution_param {
num_output: 128
pad: 1
kernel_size: 3
stride: 2
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "ReLU"
bottom: "conv4_1"
top: "conv4_1"
relu_param {
negative_slope: 0.0
layer {
type: "Convolution"
bottom: "conv4_1"
top: "conv5_1"
param {
lr_mult: 1.0
decay_mult: 0.0
param {
lr_mult: 1.0
decay_mult: 0.0
convolution_param {
num_output: 192
pad: 1
kernel_size: 3
stride: 2
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "ReLU"
bottom: "conv5_1"
top: "conv5_1"
relu_param {
negative_slope: 0.0
layer {
type: "Deconvolution"
bottom: "conv5_1"
top: "refine5_deconv"
param {
lr_mult: 1.0
decay_mult: 0.0
param {
lr_mult: 1.0
decay_mult: 0.0
convolution_param {
num_output: 128
pad: 1
kernel_size: 4
group: 1
stride: 2
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "refine5_deconv"
relu_param {
negative_slope: 0.0
layer {
type: "Concat"
bottom: "conv4_1"
top: "refine4_concat"
layer {
type: "Convolution"
bottom: "refine4_concat"
top: "refine4_conv_3x3_2"
param {
lr_mult: 1.0
decay_mult: 0.0
param {
lr_mult: 1.0
decay_mult: 0.0
convolution_param {
num_output: 128
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "ReLU"
bottom: "refine4_conv_3x3_2"
relu_param {
negative_slope: 0.0
layer {
top: "refine4_deconv"
param {
lr_mult: 1.0
decay_mult: 0.0
param {
lr_mult: 1.0
decay_mult: 0.0
convolution_param {
num_output: 96
pad: 1
kernel_size: 4
group: 1
stride: 2
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "refine4_deconv"
relu_param {
negative_slope: 0.0
layer {
type: "Concat"
bottom: "conv3_1"
top: "refine3_concat"
layer {
type: "Convolution"
bottom: "refine3_concat"
top: "refine3_conv_3x3_2"
param {
lr_mult: 1.0
decay_mult: 0.0
param {
lr_mult: 1.0
decay_mult: 0.0
convolution_param {
num_output: 96
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "ReLU"
bottom: "refine3_conv_3x3_2"
relu_param {
negative_slope: 0.0
layer {
top: "refine3_deconv"
param {
lr_mult: 1.0
decay_mult: 0.0
param {
lr_mult: 1.0
decay_mult: 0.0
convolution_param {
num_output: 64
pad: 1
kernel_size: 4
group: 1
stride: 2
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "refine3_deconv"
relu_param {
negative_slope: 0.0
layer {
type: "Concat"
bottom: "conv2_2"
top: "refine2_concat"
layer {
type: "Convolution"
bottom: "refine2_concat"
top: "refine2_conv_3x3_2"
param {
lr_mult: 1.0
decay_mult: 0.0
param {
lr_mult: 1.0
decay_mult: 0.0
convolution_param {
num_output: 64
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "ReLU"
bottom: "refine2_conv_3x3_2"
relu_param {
negative_slope: 0.0
layer {
top: "refine2_deconv"
param {
lr_mult: 1.0
decay_mult: 0.0
param {
lr_mult: 1.0
decay_mult: 0.0
convolution_param {
num_output: 48
pad: 1
kernel_size: 4
group: 1
stride: 2
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
type: "ReLU"
bottom: "refine2_deconv"
relu_param {
negative_slope: 0.0
layer {
type: "Concat"
bottom: "conv1_2"
top: "refine1_concat"
layer {
type: "Convolution"
bottom: "refine1_concat"
top: "refine1_conv_3x3_2"
param {
lr_mult: 1.0
decay_mult: 0.0
param {
lr_mult: 1.0
decay_mult: 0.0
convolution_param {
num_output: 48
pad: 1
kernel_size: 3
stride: 1
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
value: 0.0
layer {
type: "ReLU"
bottom: "refine1_conv_3x3_2"
relu_param {
negative_slope: 0.0
layer {
top: "predict"
param {
lr_mult: 1.0
decay_mult: 0.0
param {
lr_mult: 1.0
decay_mult: 0.0
convolution_param {
num_output: 12
pad: 1
kernel_size: 4
group: 1
stride: 2
weight_filler {
type: "xavier"
bias_filler {
type: "constant"
layer {
name: "Slice_[\'category_pt\', \'instance_pt\', \'confidence_pt\', \'classify_pt\', \'heading_pt\', \'height_pt\']"
type: "Slice"
bottom: "predict"
top: "category_pt"
top: "instance_pt"
top: "confidence_pt"
top: "classify_pt"
top: "heading_pt"
top: "height_pt"
slice_param {
slice_point: 1
slice_point: 3
slice_point: 4
slice_point: 9
slice_point: 11
layer {
type: "Sigmoid"
bottom: "category_pt"
top: "all_category_score"
propagate_down: false
layer {
type: "Eltwise"
bottom: "all_category_score"
bottom: "mask"
top: "category_score"
eltwise_param {
operation: PROD
layer {
type: "Sigmoid"
bottom: "confidence_pt"
top: "confidence_score"
layer {
type: "Sigmoid"
bottom: "classify_pt"
top: "class_score"
well… there it is boys… I like four(4) pieces.
--- I'm not sure this form tool is adequate in it's current capacity to accommodate files this size.
So you'd need to join each of these pieces and this is the file I can't see to get to build (with the error above)
Thanks!
Mark
@mdouglas_95136 Do you have a specific purpose for the Silence layer? The Silence layer is useful in testing and training, however I'm not sure if it was meant for use with the deployment of a network.
Thanks @Tome_at_Intel
I have asked about this layer… I've asked the owners if they could remove it. No response just yet.
--- do you know if the mvNCCompile supports "Silence" anyway? why is it barfing?
Mark
@Tome_at_Intel Just checking in here :)
===> were you able to re-assemble this deploy.prototxt file (sorry I had to send in 4 pieces)
and give it a try with mvNCCompile?
Thanks so much for the help. If the SDK supports "Silence" then this should work.
well, keep me posted.
Mark Douglas
@Tome_at_Intel just FYI: there are some known issues with your Caffe implementation listed sort of in your release notes (or this page)
https://movidius.github.io/ncsdk/Caffe.html
if you look down at
"Known Issues
Caffe Input Layer"
"Limitation: We don’t support this “input_param” format for the input layer"
so if I fix this to match the GoogLeNet same one you guys use ->
input: "data"
input_shape {
dim: 1
dim: 8
dim: 512
dim: 512
and… I remove the "Silence" layer I get different errors ->
____ start of make compile error ______*
user@user-PowerEdge-R720:~/workspace/ncsdk/examples/caffe/Apollo_GoogLeNet$ make compile
making prereqs
making prototxt
making caffemodel
making compile
[Error 17] Toolkit Error: Internal Error: Could not build graph. Missing link: data
______** end of "make compile" error ______***
So it looks like there is sufficient Caffe Input issues where you should have a guide to what might be the acceptable deploy.prototxt file.
please advise based on my last delopy.prototxt located here ->
https://github.com/ApolloAuto/apollo/blob/master/modules/perception/model/cnn_segmentation/deploy.prototxt
this happens to be the default Apollo deploy.prototxt file.
please advise.
Mark
