6591 Discussions
Low-Precision 8-bit Integer Inference on NCS2
Dal_Ben__Mattia
I haven't seen mentioned anywhere except here. Is it possibile? What are the steps required?
Shubha_R_Intel
Dear Dal Ben, Mattia,
I finally received an update.
There is still no support for int8 in OpenVINO for VPU. And currently there is no clear plan for this feature as far as future releases go.
Thanks for using OpenVino !
Shubha
Shubha_R_Intel
I think you should find the following documentation quite helpful. I read through it and I don't see any exceptions for ncs2.
https://docs.openvinotoolkit.org/latest/_inference_engine_tools_calibration_tool_README.html
There aren't any MYRIAD related calibration tool exceptions noted in the 2019 R1 Release Notes though there are some exceptions related to calibration tool. Please do a search on "calibration" on the Release Notes page.
Hope it helps you and thanks for using OpenVino !
Shubha
nikos1
Valued Contributor I
I believe low-Precision 8-bit Integer Inference is only for CPU / MKLDNN plug-in. No GPU or NCS(2) but I may be wrong. Let's try on NCS2 to find out for sure.
cheers
nikos
Shubha_R_Intel
Oops. Nikos is absolutely right. There is no INT8 support on MYRIAD. I'm terribly sorry for the misinformation but I will file a bug on the documentation, because This Should Be Clear !
Shubha
Dal_Ben__Mattia
Ok thanks for the help! @nikos @Shubha
Dal_Ben__Mattia
I'm writing here again because I'm receiving some mixed signal about the Myriad X INT8 support.
Here it's explicitly said that Myriad X has "Native FP16 and fixed point 8 bit support".
Is it a software support problem? Is this something will be available in the future?
Shubha_R_Intel
Wow. This is definitely confusing ! I have inquired about this doc you mention within Intel. I will report my findings here.
Shubha
Dal_Ben__Mattia
@Shubha That would be really helpful, thank you. I'll wait for your reply.
Dal_Ben__Mattia
@Shubha Hi, any update on this?
Shubha_R_Intel
Shubha
Jeff_at_UIUC
Hi @Shubha_R_Intel, I just confirm to be sure if INT8 is still not being supported on Myriad Neural Compute Stick 2. Thanks!
Dal_Ben__Mattia
@Shubha R.
Thank you for the information.
Shubha_R_Intel
Dal Ben, Mattia,
Of course. Thanks for using OpenVino !
Shubha
