[MTCNN] Variable input size
Wu__David
The MTCNN P-net will change input size several times, but the OpenVINO model didn't accept different input size in early release.
In R3 version, I see some posts said that we should change input shape before load into plugin like this:
net = IENetwork.from_ir(model=path_to_the_xml, weights=path_to_the_bin)
input_layer = next(iter(net.inputs))
n, c, h, w = net.inputs[input_layer]
net.reshape({input_layer: (n, c, h*2, w*2)}]
But if it does this every time, it should spend much time.
Is there another way to to this?
David
Yury_G_Intel
 One way to solve this is to create multiple networks with different size. AFAIK MTCNN has about 6 different scales, that would mean about 6 networks.
/Yury
Yury_G_Intel
/Yury
