MYRIAD_ERROR on getting result
I'm currently evaluating the Movidius Stick using some trivial mnist examples.
My setup works for regular TensorFlow models, but I get an MYRIAD_ERROR when I use a compiled Keras model. I use the docker/keras-full to train the model and create an inference.
How to reproduce:
#Imports ################# from keras.models import Model from keras.layers import Activation from keras.layers.convolutional import Conv2D from keras.layers import MaxPooling2D from keras.layers import Dense, Flatten, Dropout, Input from keras.optimizers import SGD from keras.layers.normalization import BatchNormalization from keras.initializers import RandomNormal from keras import backend as K from keras.datasets import mnist import keras from keras.preprocessing.text import one_hot from keras.utils import to_categorical import numpy as np # Constants batch_size = 128 num_classes = 10 epochs = 12 # input image dimensions img_rows, img_cols = 28, 28 # the data, split between train and test sets (x_train, y_train), (x_test, y_test) = mnist.load_data() if K.image_data_format() == 'channels_first': x_train = x_train.reshape(x_train.shape[0], 1, img_rows, img_cols) x_test = x_test.reshape(x_test.shape[0], 1, img_rows, img_cols) input_shape = (1, img_rows, img_cols) else: x_train = x_train.reshape(x_train.shape[0], img_rows, img_cols, 1) x_test = x_test.reshape(x_test.shape[0], img_rows, img_cols, 1) input_shape = (img_rows, img_cols, 1) x_train = x_train.astype('float32') x_test = x_test.astype('float32') x_train /= 255 x_test /= 255 y_train = keras.utils.to_categorical(y_train, num_classes) y_test = keras.utils.to_categorical(y_test, num_classes) inp = Input(shape=input_shape, name="model_input") conv1 = Conv2D(4,(3, 3),activation='relu',name = "Conv1")(inp) conv2 = Conv2D(8, (3, 3), activation='relu',name = "Conv2")(conv1) conv3 = Conv2D(8, (3, 3),strides=2, activation='relu',name = "Conv3")(conv2) conv4 = Conv2D(16, (3, 3),strides=2, activation='relu',name = "Conv4")(conv3) drop1 = Dropout(0.25, name = "Dropout")(conv4) conv5 = Conv2D(10, (5, 5), strides=5, activation='relu', name = "Conv5")(drop1) flat = Flatten(name = "Flatten")(conv5) softmax = Dense(num_classes, activation='softmax', name = "Softmax")(flat) model = Model(inputs=inp, outputs=softmax) model.compile(loss=keras.losses.categorical_crossentropy, optimizer=keras.optimizers.Adadelta(), metrics=['accuracy']) history = model.fit(x_train, y_train, batch_size=batch_size, epochs=epochs, verbose=1, validation_data=(x_test, y_test)) inp = Input(shape=input_shape, name="model_input") conv1 = Conv2D(4,(3, 3),activation='relu',name = "Conv1")(inp) conv2 = Conv2D(8, (3, 3), activation='relu',name = "Conv2")(conv1) conv3 = Conv2D(8, (3, 3),strides=2, activation='relu',name = "Conv3")(conv2) conv4 = Conv2D(16, (3, 3),strides=2, activation='relu',name = "Conv4")(conv3) conv5 = Conv2D(10, (5, 5), strides=5, activation='relu', name = "Conv5")(conv4) flat = Flatten(name = "Flatten")(conv5) softmax = Dense(num_classes, activation='softmax', name = "Softmax")(flat) infmodel = Model(inputs=inp, outputs=softmax) infmodel.compile(loss=model.loss, optimizer=model.optimizer, metrics=model.metrics) infmodel.set_weights(model.get_weights()) MODEL_LOC = "host/mnist_model.json" WEIGHT_LOC = "host/mnist_weights.h5" #infmodel.save("host/mnist_model.h5") with open(MODEL_LOC,"w") as f: f.write(infmodel.to_json()) infmodel.save_weights(WEIGHT_LOC) print("Model and weights saved to ", MODEL_LOC,WEIGHT_LOC)
You must change in the JSON the batch_input_shape to [1, 28, 28, 1] so the compiler doesn't get an uncaught error InvalidArgumentError (see above for traceback): You must feed a value for placeholder tensor 'model_input' with dtype float and shape [?,28,28,1] [[Node: model_input = Placeholder[dtype=DT_FLOAT, shape=[?,28,28,1], _device="/job:localhost/replica:0/task:0/device:CPU:0"]()]]
In a new file/jupyter notebook to have a clean session:
import tensorflow as tf from keras import backend as K from keras.models import Sequential import keras from tensorflow.python.tools import optimize_for_inference_lib as opti import numpy as np img_rows = 28 img_cols = 28 num_classes = 10 # Disclaimer: We do this in a seperate file with a seperate kernel to ensure # nothing carries over from the other session. # Please make sure you changed the input dimensions in the json from -1,28,28,1 to 1,28,28,1 MODEL_LOC = "host/mnist_model.json" WEIGHT_LOC = "host/mnist_weights.h5" def loadKerasModel(model_path,weight_path): # Load Trained Model with open(model_path,"r") as f: model_json = f.read() model = keras.models.model_from_json(model_json) model.load_weights(weight_path) print(model.summary()) return model model = loadKerasModel(MODEL_LOC,WEIGHT_LOC) # Convert the Keras to a Tensorflow model saver = tf.train.Saver() with K.get_session() as sess: K.set_learning_phase(0) saver.save(sess,"host/mnist_keras")
This allows me to compile the model using mvNCCompile mnist_keras.meta -in "model_input" -on "Softmax/Softmax" -o mnist_keras.graph
Running the model on the Movidius stick
#! /usr/bin/env python3 from mvnc import mvncapi as mvnc import sys import numpy import cv2 INPUT_IMAGE = "4.png" GRAPH_FILE = "./mnist_keras.graph" # Check for device existance and then open it. If no device, abort devices = mvnc.EnumerateDevices() if len(devices) == 0: print('No devices found') quit() device = mvnc.Device(devices[0]) device.OpenDevice() # Load the Graph we created before with open(GRAPH_FILE, 'rb') as f: unallocatedGraph = f.read() categories = ['0','1','2','3','4','5','6','7','8','9'] img = cv2.imread(INPUT_IMAGE) img = cv2.resize(img, (28,28)) img = cv2.cvtColor(img, cv2.COLOR_BGR2GRAY) img = img.astype(numpy.float32) print("Console Print of the Image") print("=============================") for i,x in enumerate(img): for j,y in enumerate(x): if y > 125: print("#",end="") img[i][j]= (-0.5) else: print("_",end="") img[i][j]=0.5 print("") print("=============================") # Allocate the graph graph = device.AllocateGraph(unallocatedGraph) print("Graph Allocated...") # Run it graph.LoadTensor(img.astype(numpy.float32), None) print("Network Executed...") # Get the softmax output output, userobj = graph.GetResult() print("Result Fetched...") maxidx = numpy.argmax(output) for i in range(len(output)): if i == maxidx: print(">>",end="") else: print(" ",end="") print(categories[i], output[i])
Output is
Graph Allocated... Network Executed... /usr/lib/python3/dist-packages/apport/report.py:13: DeprecationWarning: the imp module is deprecated in favour of importlib; see the module's documentation for alternative uses import fnmatch, glob, traceback, errno, sys, atexit, locale, imp Traceback (most recent call last): File "run.py", line 52, in <module> output, userobj = graph.GetResult() File "/usr/local/lib/python3.6/dist-packages/mvnc/mvncapi.py", line 264, in GetResult raise Exception(Status(status)) Exception: mvncStatus.MYRIAD_ERROR
Anybody any ideas why I get a MYRIAD_ERROR?
