Make Error 127
System Specs:
Mem - 3.8 GBs
Intel i5-5250 CPU @ 1.60 Ghz
OS type 64-bit
OS: ubuntu 16.04 LTS
This error is appearing:
making prototxt
Prototxt file already exists
making caffemodel
caffemodel file already exists
making compile
mvNCCompile -w bvlc_googlenet.caffemodel -s 12 deploy.prototxt
make[4]: mvNCCompile: Command not found
Makefile:80: recipe for target 'compile' failed
make[4]: *** [compile] Error 127
make[4]: Leaving directory '/home/jan/ncsdk/examples/caffe/GoogLeNet'
cp: cannot stat '../../caffe/GoogLeNet/graph': No such file or directory
Makefile:9: recipe for target 'googlenet' failed
make[3]: *** [googlenet] Error 1
make[3]: Leaving directory '/home/jan/ncsdk/examples/apps/multistick_cpp'
Makefile:13: recipe for target 'multistick_cpp/.' failed
make[2]: *** [multistick_cpp/.] Error 2
make[2]: Leaving directory '/home/jan/ncsdk/examples/apps'
Makefile:12: recipe for target 'apps/.' failed
make[1]: *** [apps/.] Error 2
make[1]: Leaving directory '/home/jan/ncsdk/examples'
Makefile:57: recipe for target 'examples' failed
make: *** [examples] Error 2
An earlier post suggested deleting the "graph" from ncs/..apps/multstick_cpp/cpp but I'm not quite sure which line I'm supposed to delete. Sorry, I'm new to ALL of this. Also I believe I set python path and re-installed OpenCV. Any help would be appreciated.
export PYTHONPATH=/opt/movidius/caffe/python:/opt/movidius/mvnc/python:$PYTHONPATH
I managed to get it to work after reading from another thread that OpenCV had to be reinstalled.
