6605 Discussions
Makefile:47: recipe for target 'install' failed
libprotobuf-dev : Depends: libprotobuf9 (= 2.6.1-1) but it is not going to be i nstalled
libsnappy-dev : Depends: libsnappy1 (= 1.1.2-3) but it is not going to be insta lled
libstdc++6 : Breaks: python3-scipy (<= 0.14.1-1) but 0.14.0-2 is to be installe d
libxml2-dev : Depends: libxml2 (= 2.9.1+dfsg1-5+deb8u6) but 2.9.4+dfsg1-2.2+deb 9u2 is to be installed
libxslt1-dev : Depends: libxslt1.1 (= 1.1.28-2+deb8u3) but it is not going to b e installed
protobuf-compiler : Depends: libprotobuf9 but it is not going to be installed
Depends: libprotoc9 (= 2.6.1-1) but it is not going to be i nstalled
python3-scipy : Depends: python3 (< 3.5) but 3.5.3-1 is to be installed
Recommends: g++ but it is not going to be installed or
c++-compiler
python3-yaml : Depends: python3 (< 3.5) but 3.5.3-1 is to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Installation failed: Command 'sudo apt-get install -y unzip coreutils curl git python3 libprotobuf-dev libleveldb-dev libsnappy-dev libopencv-dev libhdf5-seria l-dev protobuf-compiler libatlas-base-dev git python3-dev python3-numpy automake cmake make byacc lsb-release python3-scipy libgflags-dev libgoogle-glog-dev lib lmdb-dev swig3.0 graphviz libxslt-dev libxml2-dev gfortran python3-yaml python3- nose python-numpy python3-tk python3-pip python-pip tar wget libgraphviz-dev' re turn code=100. Error on line 308 in ./install-utilities.sh. Will exit
make: *** [install] Error 131
pi@raspberrypi:~/workspace/ncsdk $
  • 1.
Closed. Duplicate thread.
