Missing documentation of the XML files.
Deepak_C_R
I am trying to create a custom kernel by referring to cnn_custom_kernel sample code.
But I have found few XML files for which no documentation is found.
I want to know the significance of following XML files (How it is generated?, How it is used? etc..).
  • KernelsParameters.xml
  • Primitives.xml
  • StandardEnums.xml
  • CustomEnums.xml
Stav_S_Intel
The XML files you mentioned are not documented as you don;t require them for adding a custom kernel.
For adding your custom kernel to VAD you need to drag the .so file created into the custom_kernel folder and VAD will automatically identify it.
As for the XML they are used internally by VAD to document parameters types.
Stav
Stav_S_Intel
Stav
