Model Optimizer cannot handle Caffe model
redradist
Hi all,
I am trying to run `hello_reshape_ssd` example and for this I run the following commands:
```console
alias ov_model_downloader=$OPENVINO_DIR/deployment_tools/open_model_zoo/tools/downloader/downloader.py
alias ov_model_optimizer=$OPENVINO_DIR/deployment_tools/model_optimizer/mo.py
ov_model_downloader --name ssd300
ov_model_optimizer --framework caffe --input_model ./public/ssd300/models/VGGNet/VOC0712Plus/SSD_300x300_ft/VGG_VOC0712Plus_SSD_300x300_ft_iter_160000.caffemodel
And for last command I get the following error:
```console
[ FRAMEWORK ERROR ] Exception message: [Errno 2] No such file or directory: '<Some Dir>/OpenVINO/inference-engine/samples/hello_reshape_ssd/./public/ssd300/models/VGGNet/VOC0712Plus/SSD_300x300_ft/VGG_VOC0712Plus_SSD_300x300_ft_iter_160000.prototxt'
Possible reasons:
1. <Some Dir>/OpenVINO/inference-engine/samples/hello_reshape_ssd/./public/ssd300/models/VGGNet/VOC0712Plus/SSD_300x300_ft/VGG_VOC0712Plus_SSD_300x300_ft_iter_160000.prototxt does not exist
2. <Some Dir>/OpenVINO/inference-engine/samples/hello_reshape_ssd/./public/ssd300/models/VGGNet/VOC0712Plus/SSD_300x300_ft/VGG_VOC0712Plus_SSD_300x300_ft_iter_160000.prototxt does not have a valid structure, for example, it was downloaded as html
3. <Some Dir>/OpenVINO/inference-engine/samples/hello_reshape_ssd/./public/ssd300/models/VGGNet/VOC0712Plus/SSD_300x300_ft/VGG_VOC0712Plus_SSD_300x300_ft_iter_160000.prototxt contains custom layers or attributes that are not supported
in Model Optimizer by default.
After you made sure that <Some Dir>/OpenVINO/inference-engine/samples/hello_reshape_ssd/./public/ssd300/models/VGGNet/VOC0712Plus/SSD_300x300_ft/VGG_VOC0712Plus_SSD_300x300_ft_iter_160000.prototxt has a valid structure and still see this issue, then
you need to generate a python parser for caffe.proto that was used when the model
was created.
Run "python3 generate_caffe_pb2.py --input_proto ${PATH_TO_CAFFE}/src/caffe/proto/caffe.proto"
For more information please refer to Model Optimizer FAQ, question #1. (https://docs.openvinotoolkit.org/latest/openvino_docs_MO_DG_prepare_model_Model_Optimizer_FAQ.html?question=1#question-1)
[ FRAMEWORK ERROR ] Model Optimizer is not able to parse <Some Dir>/OpenVINO/inference-engine/samples/hello_reshape_ssd/./public/ssd300/models/VGGNet/VOC0712Plus/SSD_300x300_ft/VGG_VOC0712Plus_SSD_300x300_ft_iter_160000.prototxt
By some reason model optimizer cannot parse properly model that I downloaded from Open Model Zoo ...
Maybe I've missed some dependency ?
Seems like by some reason Model Optimizer detects this model as Tensorflow, because it tries to read .prototxt
redradist
I've checked ... issue fixed with Python 3.8 !!
Zulkifli_Intel
Hello Denis Kotov,
Thank you for contacting us.
To convert the Caffee model to IR:
python3 mo_caffee.py --input_model /path/to/VGG_VOC0712Plus_SSD_300x300_ft_iter_160000.caffeemodel --input_proto /path/to/deploy.pototxt
Please visit Hello Reshape SSD C++ Sample page for more information.
Zulkifli
redradist
I've checked it previously, but also I've read Model Optimizer documentation https://docs.openvinotoolkit.org/2021.2/openvino_docs_MO_DG_prepare_model_convert_model_Convert_Model_From_Caffe.html
And there you can see there following line:
python3 mo.py --input_model <INPUT_MODEL>.caffemodel
 It seems like documentation is outdated ?
Also I've tested your command as it:
python3 $OPENVINO_DIR/deployment_tools/model_optimizer/mo_caffe.py --input_model ./public/ssd300/models/VGGNet/VOC0712Plus/SSD_300x300_ft/VGG_VOC0712Plus_SSD_300x300_ft_iter_160000.caffemodel --input_proto ./public/ssd300/models/VGGNet/VOC0712Plus/SSD_300x300_ft/deploy.prototxt
And I still have got the same error ... (
Zulkifli_Intel
Hello Denis Kotov,
What is the OpenVINO version that you use?
Try to put the full path to the input model and input proto. For instant:
python3 mo_caffee.py --input_model /opt/intel/openvino_2021.2.185/deployment_tools/open_model_zoo/tools/downloader/public/ssd300/models/VGGNet/VOC0712Plus/SSD_300x300_ft/VGG_VOC0712Plus_SSD_300x300_ft_iter_160000.caffemodel --input_proto /opt/intel/openvino_2021.2.185/deployment_tools/open_model_zoo/tools/downloader/public/ssd300/models/VGGNet/VOC0712Plus/deploy.prototxt/
Zulkifli
redradist
I've tested with full path and the same issue ...
The version I am testing is `releases/2021/3`
And I am using downloaded models from Zoo that is located in current folder like `$PWD/public/ssd300/models/VGGNet/VOC0712Plus/SSD_300x300_ft/VGG_VOC0712Plus_SSD_300x300_ft_iter_160000.caffemodel`
Zulkifli_Intel
Hello Denis Kotov,
Please try these steps.
Install the dependencies.
Go to dependencies directory:
cd /opt/intel/openvino_2021/install_dependencies
Run the script:
sudo -E ./install_openvino_dependencies.sh
Set the environment variable:
source /opt/intel/openvino_2021/bin/setupvars.sh
Install the prerequisites:
Go to the Model Optimizer prerequisites directory:
cd /opt/intel/openvino_2021/deployment_tools/model_optimizer/install_prerequisites
Run the script:
sudo ./install_prerequisites.sh
Please inform us if you encounter any error while installing dependencies and prerequisites.
Zulkifli
redradist
Nope ... still this issue:
[ ERROR ] Error while emitting attributes for layer relu1_1 (id = 5). It usually means that there is unsupported pattern around this node or unsupported combination of attributes.
Zulkifli_Intel
Hello Denis Kotov,
Can you share the Python version that you are using?
Zulkifli
redradist
redradist
Seems like I have found the similar issue:
https://github.com/openvinotoolkit/openvino/issues/3823
Probably it is relate to python version ... I will check
redradist
Zulkifli_Intel
Hello Denis,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Zulkifli
