I tried to convert the Mozilla DeepSpeech Mode to IR model as mentioned in your page. But the converter fails with internal error:
python ./mo_tf.py --input_model "D:\Programming\deepSpeech\models\output_graph.pb" --freeze_placeholder_with_value "input_lengths->[16]" --input input_node,previous_state_h/read,previous_state_c/read --input_shape [1,16,19,26],[1,2048],[1,2048] --output raw_logits,lstm_fused_cell/Gather,lstm_fused_cell/Gather_1
Model Optimizer arguments:
Common parameters:
- Path to the Input Model: D:\Programming\deepSpeech\models\output_graph.pb
- Path for generated IR: C:\Intel\computer_vision_sdk\deployment_tools\model_optimizer\.
- IR output name: output_graph
- Log level: ERROR
- Batch: Not specified, inherited from the model
- Input layers: input_node,previous_state_h/read,previous_state_c/read
- Output layers: raw_logits,lstm_fused_cell/Gather,lstm_fused_cell/Gather_1
- Input shapes: [1,16,19,26],[1,2048],[1,2048]
- Mean values: Not specified
- Scale values: Not specified
- Scale factor: Not specified
- Precision of IR: FP32
- Enable fusing: True
- Enable grouped convolutions fusing: True
- Move mean values to preprocess section: False
- Reverse input channels: False
TensorFlow specific parameters:
- Input model in text protobuf format: False
- Offload unsupported operations: False
- Path to model dump for TensorBoard: None
- List of shared libraries with TensorFlow custom layers implementation: None
- Update the configuration file with input/output node names: None
- Use configuration file used to generate the model with Object Detection API: None
- Operations to offload: None
- Patterns to offload: None
- Use the config file: None
Model Optimizer version: 1.5.12.49d067a0
[ ERROR ] -------------------------------------------------
[ ERROR ] ----------------- INTERNAL ERROR ----------------
[ ERROR ] Unexpected exception happened.
[ ERROR ] Please contact Model Optimizer developers and forward the following information:
[ ERROR ] Exception occurred during running replacer "None (<class 'extensions.front.tf.BlockLSTM.BlockLSTM'>)": 7
[ ERROR ] Traceback (most recent call last):
File "C:\Intel\computer_vision_sdk\deployment_tools\model_optimizer\mo\utils\class_registration.py", line 114, in apply_replacements
replacer.find_and_replace_pattern(graph)
File "C:\Intel\computer_vision_sdk\deployment_tools\model_optimizer\mo\front\common\replacement.py", line 125, in find_and_replace_pattern
apply_pattern(graph, action=self.replace_sub_graph, **self.pattern())
File "C:\Intel\computer_vision_sdk\deployment_tools\model_optimizer\mo\middle\pattern_match.py", line 95, in apply_pattern
action(graph, match)
File "C:\Intel\computer_vision_sdk\deployment_tools\model_optimizer\mo\front\common\replacement.py", line 189, in replace_sub_graph
self.replace_output_edges(graph, self.gen_output_edges_match(node, self.replace_op(graph, node)))
File "C:\Intel\computer_vision_sdk\deployment_tools\model_optimizer\extensions\front\tf\BlockLSTM.py", line 84, in replace_op
[graph.remove_edge(node.in_node(p).id, node.id) for p, input_data in node.in_nodes().items() if p in [5, 6, 7]]
File "C:\Intel\computer_vision_sdk\deployment_tools\model_optimizer\extensions\front\tf\BlockLSTM.py", line 84, in <listcomp>
File "C:\Intel\computer_vision_sdk\deployment_tools\model_optimizer\mo\graph\graph.py", line 329, in in_node
return self.in_nodes(control_flow=control_flow)[key]
KeyError: 7
The above exception was the direct cause of the following exception:
File "C:\Intel\computer_vision_sdk\deployment_tools\model_optimizer\mo\main.py", line 325, in main
return driver(argv)
File "C:\Intel\computer_vision_sdk\deployment_tools\model_optimizer\mo\main.py", line 267, in driver
mean_scale_values=mean_scale)
File "C:\Intel\computer_vision_sdk\deployment_tools\model_optimizer\mo\pipeline\tf.py", line 248, in tf2nx
class_registration.apply_replacements(graph, class_registration.ClassType.FRONT_REPLACER)
File "C:\Intel\computer_vision_sdk\deployment_tools\model_optimizer\mo\utils\class_registration.py", line 127, in apply_replacements
)) from err
Exception: Exception occurred during running replacer "None (<class 'extensions.front.tf.BlockLSTM.BlockLSTM'>)": 7
[ ERROR ] ---------------- END OF BUG REPORT --------------
The only thing I have changed is the quotes for the freeze placeholder value argument as it threw an error asking to use this format.
Dear Tyurin, Sergey,
Thanks for sharing with the OpenVino community !
Shubha
With release 0.5.1 you can use script:
@echo off setlocal set TMP_HOME=%~dp0 set DS_HOME=%TMP_HOME:~0,-1% set DS_MODEL_VER=deepspeech-0.5.1-models set MO_TF="%INTEL_OPENVINO_DIR%\deployment_tools\model_optimizer\mo_tf.py" :: Model URL - https://github.com/mozilla/DeepSpeech/releases/download/v0.5.1/deepspeech-0.5.1-models.tar.gz set OUT_GRAPH=%DS_HOME%\%DS_MODEL_VER%\output_graph.pb set ALPHBET=%DS_HOME%\%DS_MODEL_VER%\alphabet.txt set LM_BINARY=%DS_HOME%\%DS_MODEL_VER%\lm.binary set TRIE=%DS_HOME%\%DS_MODEL_VER%\trie if not exist %DS_HOME%\tb_log ( mkdir %DS_HOME%\tb_log ) python %MO_TF% ^ --input_model %OUT_GRAPH% ^ --freeze_placeholder_with_value "input_lengths->[16]" ^ --input "input_node,previous_state_h/read,previous_state_c/read" ^ --input_shape "[1,16,19,26],[1,2048],[1,2048]" ^ --output raw_logits,lstm_fused_cell/GatherNd,lstm_fused_cell/GatherNd_1 ^ --log_level WARNING ^ --tensorboard_logdir "%DS_HOME%\tb_log" endlocal exit /b 0
