6595 Discussions
Model Optimizer for tensorflow model - Object detection ssd_mobilenet_v1
Truong__Dien_Hoa
New Contributor II
I have a tensorflow frozen model .pb obtained from this tutorial github.com/jkjung-avt/hand-detection-tutorial .
This tuto based on the original tensorflow object detection repository so I think there aren't something special.
I tried to optimize the model with :
 python3 mo_tf.py --input_model /home/ben/hand-detection-tutorial/model_exported/frozen_inference_graph.pb
But I encountered an error below:
[ ERROR ]  Shape [-1 -1 -1  3] is not fully defined for output 0 of "image_tensor". Use --input_shape with positive integers to override model input shapes.
So I retried with putting shape
python3 mo_tf.py --input_model /home/ben/hand-detection-tutorial/model_exported/frozen_inference_graph.pb --input_shape [1,300,300,3]
Still got an error:
[ ERROR ]  Shape is not defined for output 0 of "Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Slice".
[ ERROR ]  Cannot infer shapes or values for node "Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Slice".
[ ERROR ]  Not all output shapes were inferred or fully defined for node "Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Slice".
Someone have idea how I can fix the problem ? Thank you in advance
Talbi__Ahmed
Which model did you train? if it's the SSD you have to specify using the .json file as specified in the tutoriel. <INSTALL_DIR>/deployment_tools/model_optimizer/extensions/front/tf
this is based on the tensorflow object detection api so for the ssd you should use ssd_v2_support.json.
As first step you should try to convert the frozen pretrained model (a good exercise and helps you to understand how to use the mo_tf script) adapt the following command:
./mo_tf.py --input_model <Path_Model>/frozen_inference_graph.pb --tensorflow_object_detection_api_pipeline_config <Path to config file>/pipeline.config --tensorflow_use_custom_operations_config extensions/front/tf/ssd_v2_support.json --output="detection_boxes,detection_scores,num_detections" --output_dir Desktop --reverse_input_channels --log_level DEBUG
After retraining you will most probably have an Error with the tensorflow version (open vino uses 1.2 and Object detection api have a trouble with it) to solve it create a virtual env and install the same tensorflow you are using to export the models.
cheers.
Jakub
instead of:
try using:
-b 1
Truong__Dien_Hoa
New Contributor II
Thank you so much @Jakub. I understand better how open vino works now.
Actually now I stuck in another bug that can not parse the config file
[ ERROR ]  Failed to convert tokens to dictionary: Wrong character "Use" in position 62
[ ERROR ]  Failed to generate dictionary representation of file.
You find the config file in the attachment
Sorry for bother you so much, I am not familiar with Openvino and also tensorflow. I worked before with Pytorch and at first try to convert the model to .onnx file to use with open vino, but there are some functions are not implemented yet so I switched to tensorflow.
Jakub
Hi @Truong,
Have a look at this thread: https://software.intel.com/en-us/forums/computer-vision/topic/785586 . There is also the "[ ERROR ]  Failed to convert tokens to dictionary:" error
I hope it will help you,
Jakub
Truong__Dien_Hoa
New Contributor II
Thank you so much @Jakub, I just asked a question there.
Truong__Dien_Hoa
New Contributor II
Hi @Talbi Ahmed , Seems a long time since my post but I would like to say thank you. I was not pay attention and was thinking you and @jakub are the same person. Today I revisited this thread and solve my new problem with tensorflow version as you mentionned openvino does not support the latest tensorflow :D
Hoa
GKund1
I had the same problem, I had a layer defined in tf via:
model.add(tf.keras.layers.Dense(128, activation=tf.nn.relu,input_shape= x_train.shape[1:]))
print(x_train.shape[1:])) gives (784,)
so I used the model optimizer with  -- input_shape[784] which gave errors - eventually I found your -b 1
please explain why this is the solution. Thanks Gerd
Jakub wrote:
instead of:
try using:
-b 1
