Environment:
Os: Ubuntu 18.04
Model Optimizer version: 2019.2.0-436-gf5827d4
I'm trying to convert EAST TensorFlow implementation model, that can be download in this link, to IR openvino model. This implementation can be found here. When I tried to run the following code:
python3 /opt/intel/openvino/deployment_tools/model_optimizer/mo_tf.py --input_meta_graph east_icdar2015_resnet_v1_50_rbox/model.ckpt-49491.meta
The following error was presented:
Model Optimizer arguments:
Common parameters:
- Path to the Input Model: None
- Path for generated IR: /root/.
- IR output name: model.ckpt-49491
- Log level: ERROR
- Batch: Not specified, inherited from the model
- Input layers: Not specified, inherited from the model
- Output layers: Not specified, inherited from the model
- Input shapes: Not specified, inherited from the model
- Mean values: Not specified
- Scale values: Not specified
- Scale factor: Not specified
- Precision of IR: FP32
- Enable fusing: True
- Enable grouped convolutions fusing: True
- Move mean values to preprocess section: False
- Reverse input channels: False
TensorFlow specific parameters:
- Input model in text protobuf format: False
- Path to model dump for TensorBoard: None
- List of shared libraries with TensorFlow custom layers implementation: None
- Update the configuration file with input/output node names: None
- Use configuration file used to generate the model with Object Detection API: None
- Operations to offload: None
- Patterns to offload: None
- Use the config file: None
[ ERROR ] Exception occurred during running replacer "None" (<class 'extensions.front.tf.assign_elimination.AssignSubElimination'>): Data flow edge coming out of AssignSub node model_1/resnet_v1_50/block3/unit_4/bottleneck_v1/conv2/BatchNorm/AssignMovingAvg
I've searched in the openvino forum to find a solution but I'm not able to solve. Can you help me?
Felipe Ximenes
Hi Felipe,
The EAST model is currently not supported by the OpenVINO toolkit. However, there is a feature request for the development team to consider and potentially enable it in a future software release. We do have a text detection/recognition demo and models available, see the demo documentation here.
Please let me know if you have additional questions.
Jesus
Hi Jesus,
Thanks for your explanation. I am interested in porting EAST to openvino. Can I help development team to implement this feature, if possible? I don't know how exactly to do that but if you give me the directions, I can help.
Felipe Ximenes
