Model that does nothing
I am trying to build a model for the NCS that does nothing. When compiling the model I get an error
shape: (400, 400) res.shape: (400, 400) TensorFlow output shape: (1, 400, 400) Traceback (most recent call last): File "/usr/local/bin/mvNCCompile", line 169, in <module> create_graph(args.network, args.image, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights, args.explicit_concat, args.ma2480, args.scheduler, args.new_parser, args) File "/usr/local/bin/mvNCCompile", line 148, in create_graph load_ret = load_network(args, parser, myriad_config) File "/usr/local/bin/ncsdk/Controllers/Scheduler.py", line 110, in load_network network.optimize() File "/usr/local/bin/ncsdk/Models/Network.py", line 250, in optimize self.convert_network_input_to_yxz() File "/usr/local/bin/ncsdk/Models/Network.py", line 337, in convert_network_input_to_yxz if self.stageslist[0].op in [StageType.fully_connected_layer, StageType.convolution, StageType.max_pooling, IndexError: list index out of range
My model is build as follows:
import tensorflow as tf import numpy as np def main(_): graph = tf.Graph() with graph.as_default(): with tf.Session(graph=graph) as sess: x = tf.placeholder(tf.float32, [400, 400], name='input') for n in tf.get_default_graph().as_graph_def().node: print(n.name + ": " + n.op) sess.run(tf.global_variables_initializer()) sess.run(tf.local_variables_initializer()) # test model in_tensor = tf.get_default_graph().get_tensor_by_name('input:0') input_data = np.random.rand(400, 400).astype(np.float32) known = sess.run('input:0', {in_tensor: input_data}) print('Result: ' + str(known)) # attempts to use saver but fails due to no variables to save #saver = tf.train.Saver(tf.global_variables()) #saver.save(sess, './empty') tf.train.write_graph(sess.graph_def, './', 'empty.pb', as_text=False) tf.app.run(main=main)
Any idea on how to get past this hurdle?
oh bro,
you can use mvNCCheck tools to check if your model has been translate successfully,
the tool's documentation in this site : https://movidius.github.io/ncsdk/tools/check.html
bro, mvNCCheck gives me the same error…
my guess is it doesn't like that the model doesn't have any weights
