Multi-dimension Output
LEE__JS1
I am suffering for dealing with the Multi-dimensional Output in Openvino.
As far as I found, the output data could be obtained with the code below.
>> const auto data = inferRequest.GetBlob(LprOutputName)->buffer().as<float*>();
But how can I deal with the multi-dementional output ?
For example, the output could be 1-1-2-3 or 1-2-3-4.
Can anybody help me ?
JesusE_Intel
Hi JS,
It depends on the model, for example face-detection-adas-004 from the Intel pre-trained models. The output is a blob with shape [1,1,N,7] each detection has the following format:
[image_id, label, conf, x_min, y_min, x_max, y_max], where:
image_id - ID of the image in the batch
label - predicted class ID
conf - confidence for the predicted class
(x_min, y_min) - coordinates of the top left bounding box corner
(x_max, y_max) - coordinates of the bottom right bounding box corner.
 https://github.com/opencv/open_model_zoo/blob/master/models/intel/face-detection-retail-0004/description/face-detection-retail-0004.md#outputs
Take a look at the Interactive Face Detection Demo source on how the output blob is handled.
Jesus
LEE__JS1
Dear Jesus E. (Intel),
Sorry for late reply and so much thanks to you for your message.
I would like to download the model you mentioned and test with it.
After the test, I will let you know about the result again.
JS
