6614 Discussions
Multiple NSC2 working together on an inference
BuuVo
Hi every body,
I am doing a project to classify images with NCS2. I successfully classify images when I used only one NCS2, and the inference time is ~0.37(s).
The inference time is calculated as the following lines of code:
time_pre = time.time()
outputs = exec_net.infer({'data':inputs})
time_post = time.time()
inferrenc_time = time_pre - time_post
However, when I used 2 NSC2 and configured openVino IECore like below:
plugin = IECore()
net = plugin.read_network(model=model_xml, weights=model_bin)
exec_neto = plugin.load_network(network=net,                      device_name='HETERO:MYRIAD.1.1.2-ma2480,MYRIAD.1.2-ma2480')
The inference time doesn't reduce. It is still ~ 0.37(s). I also check the query layers map, and all layers are always assigned to one NCS2 device (Please refer to the image)
How can I change the setting to speed up my system by using multiple NCS2?
I referred to this tutorial but I didn't success:
https://www.coursera.org/lecture/int-openvino/using-multiple-devices-s976F
Thank you.
IntelSupport
Community Manager
Hi BuuVo,
The heterogeneous plugin enables computing for inference on one network on several devices. Purposes to execute networks in the heterogeneous mode are as follows:
·      To utilize accelerators power and calculate heaviest parts of the network on the accelerator and execute not supported layers on fallback devices like CPU
·      To utilize all available hardware more efficiently during one inference
However, since you are using a hetero plugin with identical devices it is only natural that the execution will be done in the first device.
A single inference can be split into multiple inferences to be handled by separate devices. Please refer to the following sections,  "Annotation of Layers per Device and Default Fallback Policy", "Details of Splitting Network and Execution" and "Execution Precision" in the following link:
https://docs.openvinotoolkit.org/latest/openvino_docs_IE_DG_supported_plugins_HETERO.html
Please also refer to the following link for an example of implementation.
https://github.com/yuanyuanli85/open_model_zoo/tree/ncs2/demos/python_demos
You can go through this community discussion that might be helpful to you as well.
https://community.intel.com/t5/Intel-Distribution-of-OpenVINO/How-to-use-Multi-Stick-NCS2-Parallelization-of-reasoning/td-p/1181316
Please refer to the Multi-Device Plugin and Hello Query Device C++ Sample pages for additional relevant information.
https://docs.openvinotoolkit.org/latest/openvino_inference_engine_samples_hello_query_device_README.html
https://docs.openvinotoolkit.org/latest/openvino_docs_IE_DG_supported_plugins_MULTI.html
Aznie
BuuVo
Any Help?
IntelSupport
Community Manager
Hi BuuVo,
We are currently working on this. We will get back to you shortly.
Aznie
IntelSupport
Community Manager
Hi BuuVo,
Aznie
BuuVo
IntelSupport
Community Manager
Hi Buu Vo,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Aznie
