6594 Discussions
Multiple modules files integrated with OpenVINO on VC++ environment
WeiSeng
Hi Support Team,
Like to check with you, for OpenVINO we provide reference VC++ project that running single module files.
If we have multiple modules need to integrate with OpenVINO VC++ project, is we have guide for this or reference?
Thanks!
Megat_Intel
Hi WeiSeng,
Could you please elaborate more on the single/multiple "module files"? Are you referring to adding modules in the OpenVINO™ CMake Build plugin?
If you are trying to add module packages (e.g., OpenCV) to your project, you can refer to the guide on the Build Plugin Using CMake page. On another note, if you are adding a module as an extension for a custom operation, please check out the steps on how to Create a Library with Extensions.
For additional information, you can also check out the guide on Running OpenVINO C++ samples on Visual Studio.
Megat
WeiSeng
Thanks!! We will reference this.
Megat_Intel
Hi WeiSeng,
Thank you for your question. This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Megat
