NCS2 in Kubernetes support?
Sack__Alexander
I am following the install instructions here to build my own Docker container:
https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_docker_linux.html
Solution #1 points out that it might conflict with k8s. However, solution #2 works around that by getting rid of udev. That works! I am able to build my image and run it under docker and run the sample code successfully.
However, I have not been so lucky getting that container to work as a Pod under k8s- I have tried many, many things but every time the USB reset happens during a network load I see NC_ERROR as a result.
Is there a way to get NCS2 to work under a container within k8s?
Thanks!
Sack__Alexander
Ok, update: It does work at least if I mount all of /dev if I put the Pod in privileged mode.Is there an official guide on how to run OpenVINO within a Pod?
Note: The 2020.1.023 package for Raspian doesn't seem to support python3.6.
MAURICIOAL_R_Intel
Thanks for reaching out.
We are doing some research to come back to you with the best possible solution.
Mauricio R.
MAURICIOAL_R_Intel
Hello, check this guide that might be useful for your issue.
Mauricio R.
