NCS2 not working on Raspberry PI 3B+
Hi, Guys
i installed ncssdk on my raspberry Pi 3B+. However when i tried to run hello_ncs_py
i got the following error message.
_D: [ 0] ncDeviceCreate:308 ncDeviceCreate index 0
D: [ 0] ncDeviceCreate:308 ncDeviceCreate index 1
D: [ 0] ncDeviceOpen:524 File path /usr/local/lib/mvnc/MvNCAPI-ma2480.mvcmd
W: [ 0] ncDeviceOpen:528 ncDeviceOpen() XLinkBootRemote returned error 3
Error - Could not open NCS device_
what should i do to fix this problem?
thanks a lot
Julian
here is the result from lsusb
Bus 001 Device 006: ID 03e7:2485
Bus 001 Device 004: ID 0424:7800 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
the first line seems NCS2 has already connected on raspberry Bi 3
