6605 Discussions
NCSDK 2 installation Error 【131】after the NCSDK 1 uninstallation
root@ubuntu:~/workspace# cd ncsdk
root@ubuntu:~/workspace/ncsdk# ls
api examples install.sh Makefile requirements_apt_raspbian.txt uninstall-opencv.sh
ATTRIBUTIONS extras install-utilities.sh ncsdk.conf requirements_apt.txt uninstall.sh
docs install-opencv.sh LICENSE README.md requirements.txt version.txt
root@ubuntu:~/workspace/ncsdk# make install
./uninstall-opencv.sh
OpenCV uninstall starting
Reading installer configuration variables from ./ncsdk.conf
You are using pip version 8.1.1, however version 10.0.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
OpenCV uninstall finished
make install starting.
./install.sh
Movidius Neural Compute Toolkit Installation
Installer NCSDK version: 2.04.00.06
Installing on Ubuntu 16.04
print_ncsdk_config()
INSTALL_DIR - Main installation directory
INSTALL_CAFFE - Flag to install TensorFlow
CAFFE_FLAVOR - Specific 'flavor' of caffe to install
CAFFE_USE_CUDA - Use CUDA enabled version of caffe
INSTALL_TENSORFLOW - Flag to install TensorFlow
INSTALL_TOOLKIT - Flag to install Neural Compute Toolkit
PIP_SYSTEM_INSTALL - Globally install pip packages via sudo -H
VERBOSE - Flag to enable more verbose installation
USE_VIRTUALENV - Flag to enable python virtualenv
MAKE_NJOBS - Number of processes to use for parallel build (i.e. make -j MAKE_NJOBS)
INSTALL_DIR=/opt/movidius
INSTALL_CAFFE=yes
CAFFE_FLAVOR=ssd
CAFFE_USE_CUDA=no
INSTALL_TENSORFLOW=yes
INSTALL_TOOLKIT=yes
PIP_SYSTEM_INSTALL=yes
VERBOSE=yes
USE_VIRTUALENV=no
MAKE_NJOBS=2
Didn't find a valid NCSDK installation
Searching and removing previous NCSDK installation from the system
Searching and removing NCS python API…You are using pip version 8.1.1, however version 10.0.1 is available.
Uninstalling mvnc-1.12.0.1:
Successfully uninstalled mvnc-1.12.0.1
done
Searching and removing udev rules…done
Running ldconfig…done
Updating udev rules…done
Successfully uninstalled NCSDK from the system
Downloading NCSDK-2.04.00.06.tar.gz
--2018-06-12 21:11:38-- https://downloadmirror.intel.com/27738/eng/NCSDK-2.04.00.06.tar.gz
Resolving downloadmirror.intel.com (downloadmirror.intel.com)… 23.48.22.30
Connecting to downloadmirror.intel.com (downloadmirror.intel.com)|23.48.22.30|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 1383386 (1.3M) [application/x-gzip]
Saving to: ‘NCSDK-2.04.00.06.tar.gz’
http://ppa.launchpad.net/fcitx-team/nightly/ubuntu xenial/main DEP-11 64x64 Icons
Err:9 http://ppa.launchpad.net/fcitx-team/nightly/ubuntu xenial/main Sources
404 Not Found
Ign:12 http://ppa.launchpad.net/fcitx-team/nightly/ubuntu xenial/main amd64 Packages
Ign:15 http://ppa.launchpad.net/fcitx-team/nightly/ubuntu xenial/main i386 Packages
Ign:16 http://ppa.launchpad.net/fcitx-team/nightly/ubuntu xenial/main all Packages
Ign:17 http://ppa.launchpad.net/fcitx-team/nightly/ubuntu xenial/main Translation-en_US
Ign:18 http://ppa.launchpad.net/fcitx-team/nightly/ubuntu xenial/main Translation-en
Ign:19 http://ppa.launchpad.net/fcitx-team/nightly/ubuntu xenial/main amd64 DEP-11 Metadata
Ign:22 http://ppa.launchpad.net/fcitx-team/nightly/ubuntu xenial/main DEP-11 64x64 Icons
Fetched 4,610 kB in 46s (99.7 kB/s)
Reading package lists…
W: The repository 'http://ppa.launchpad.net/fcitx-team/nightly/ubuntu xenial Release' does not have a Release file.
E: Failed to fetch http://ppa.launchpad.net/fcitx-team/nightly/ubuntu/dists/xenial/main/source/Sources 404 Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
Installation failed: Command ' apt-get update' return code=100. Error on line 308 in ./install-utilities.sh. Will exit
Makefile:47: recipe for target 'install' failed
make: *** [install] Error 131
@ideallyworld The NCSDK installation script performs a sudo apt-get update while installing the NCSDK. It seems like you may have some broken packages that is impeding the update command and thus making the installation fail.
@Tome_at_Intel I trial it follow your comments, It meet the same result W/ sudo apt-get update ,so it seems the root cause . But how could I fix this problem? Could you pls give me a help? Thanks.
root@ubuntu:~/workspace/ncsdk# sudo apt-get update
Ign:1 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:2 http://security.ubuntu.com/ubuntu xenial-security InRelease
Hit:3 http://us.archive.ubuntu.com/ubuntu xenial InRelease
Hit:4 http://dl.google.com/linux/chrome/deb stable Release
Ign:5 http://ppa.launchpad.net/fcitx-team/nightly/ubuntu xenial InRelease
Hit:6 http://us.archive.ubuntu.com/ubuntu xenial-updates InRelease
Hit:8 http://us.archive.ubuntu.com/ubuntu xenial-backports InRelease
Ign:9 http://ppa.launchpad.net/fcitx-team/nightly/ubuntu xenial Release
Hit:10 http://archive.ubuntukylin.com:10006/ubuntukylin xenial InRelease
Ign:11 http://ppa.launchpad.net/fcitx-team/nightly/ubuntu xenial/main Sources
Ign:13 http://ppa.launchpad.net/fcitx-team/nightly/ubuntu xenial/main i386 Packages
Ign:14 http://ppa.launchpad.net/fcitx-team/nightly/ubuntu xenial/main all Packages
Ign:15 http://ppa.launchpad.net/fcitx-team/nightly/ubuntu xenial/main Translation-en_US
Ign:16 http://ppa.launchpad.net/fcitx-team/nightly/ubuntu xenial/main Translation-en
Ign:17 http://ppa.launchpad.net/fcitx-team/nightly/ubuntu xenial/main amd64 DEP-11 Metadata
Ign:18 http://ppa.launchpad.net/fcitx-team/nightly/ubuntu xenial/main DEP-11 64x64 Icons
Err:11 http://ppa.launchpad.net/fcitx-team/nightly/ubuntu xenial/main Sources
404 Not Found
Reading package lists… Done
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Hi! I am incurring in the sabe problem. Did you manage to solve this? If so, can you please tell me what you did? Thanks, and have a great weekend.
