6593 Discussions
NCSDK build error (liblapack and libblas linking issue)
I cloned the latest github repo on my Ubuntu 16.04 machine and when I tried to build the code using "make install", I'm seeing the following errors:
[ 94%] Built target convert_mnist_siamese_data
make[3]: Entering directory '/opt/movidius/ssd-caffe/build'
make[3]: Leaving directory '/opt/movidius/ssd-caffe/build'
[ 94%] Linking CXX executable ssd/ssd_detect
/usr/bin/ld: /usr/local/lib/liblapack.a(sgetrf2.o): undefined reference to symbol 'sscal_'
//usr/lib/libopenblas.so.0: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
examples/CMakeFiles/ssd_detect.dir/build.make:136: recipe for target 'examples/ssd/ssd_detect' failed
make[3]: *** [examples/ssd/ssd_detect] Error 1
CMakeFiles/Makefile2:1075: recipe for target 'examples/CMakeFiles/ssd_detect.dir/all' failed
make[2]: *** [examples/CMakeFiles/ssd_detect.dir/all] Error 2
make[2]: Leaving directory '/opt/movidius/ssd-caffe/build'
Makefile:127: recipe for target 'all' failed
make[1]: *** [all] Error 2
make[1]: Leaving directory '/opt/movidius/ssd-caffe/build'
Installation failed. Error on line 498
I checked for the liblapack and libblas libraries and they look good. I spent two hours looking up for solutions online but in vain.
Can somebody please help me with this issue?
Venky
@kodukulav Have you tried the NCSDK installation on a fresh machine? Also I was just wondering if you are you using Anaconda? There has been known issues with virtual environment software with the current NCSDK (1.12). If you can, I recommend trying the installation on a fresh machine.
@Tome_at_Intel Thanks for your suggestion. I tried installing NCSDK on a virtual box with a Ubuntu 16.04 running on it. The installation is successful.
@kodukulav Glad to hear that!
