NCSDK2 installation Error
My system is ubuntu16.04 LTS, I just tried to install NCSDK2 and got an error during the step2 "make install", I installed NCSDK2 follow these steps:
1.download the ncsdk.tar from https://github.com/movidius/ncsdk.
2.decompression the ncsdk.tar
3.cd the ncsdk setup package position.
4.sudo make install (also tried use root user to make install )
the error showed "cannot install caffe ssd", then I tried to modified the ncsdk.conf document(remove the caffe setup option) in the setup package and add the PYTHONPATH in the system file , but it cannot work.
I also tried to install NCSDK2 online, but it showed that lack many install packages.
Hi @xzarf
Could you try the following commands to download and install the ncsdk2 (v2.08)? Please copy/paste the full error you are seeing.
git clone -b ncsdk2 https://github.com/movidius/ncsdk.git cd ncsdk make install
Jesus
thanks Jesus, the problem has been solved.
