6592 Discussions
NNCF post-training quantization - What is wrong?
LFan
I am trying NNCF post-training quantization (PTQ) on a U-net model, hoping to improve the inference speed. The neural network is originally trained in PyTorch, converted to OpenVINO, and then quantized using NNCF using PTQ.
Below is the steps and code snippet for PTQ part:
        # Post-Training Quantization (PTQ) with NNCF
        import nncf
        # Step 1: Define a transformation function for calibration
        def transform_fn(data_item
            inputs, _, _ = data_item  # Extract inputs from the data loader
            if bSingleInputTensor:
                # Ensure the input tensor matches the model's expected format
                return inputs[0].unsqueeze(1).float().numpy()  # Add channel dimension, ensure float32
            else:
                # Ensure both input tensors match the model's expected format
                return {
                    0: inputs[0].unsqueeze(1).float().numpy(),  # First input tensor
                    1: inputs[1].unsqueeze(1).float().numpy()   # Second input tensor
        # Step 2: Create an NNCF Dataset using joinedDataLoader
        calibration_dataset = nncf.Dataset(joinedDataLoader, transform_fn)
        # Step 3: Perform quantization
        quantized_model = nncf.quantize(ov_unet_model, calibration_dataset)
        print("Quantization completed successfully.")
        # Step 4: Save the quantized model using the new function
        self.WriteQuantizedOpenVINOModelsForDeployment(quantized_model, bWriteInfoFile=True)
The PTQ shows that only ~7% of the model was quantized.
When comparing the inference runtime between Torch, OpenVINO, and OpenVINO Quantized models, the quantized model turns out to be ~10% slower than the original OpenVINO model.
Please let me know if you need anything else.
If possible, I would greatly appreciate if we can schedule a meeting to discuss this issue.
Li
Zulkifli_Intel
Hi LFan,
Thank you for reaching out.
Please share the required files/scripts to reproduce the issue. Can you share the necessary files/scripts for the case 06612870 as well? I'm checking if scheduling a meeting is possible.
Zul
LFan
Thank you for the reply! It would be great if we can talk directly.
Can we share files that are Intel confidential in this forum? It looks like anyone can download the attachments... Is there a more confidential way to share files?
Thanks for the help.
n_scott_pearson
OMG, NO! This is an open forum. No Confidential information should be shared here. You should only share Confidential information with Intel folks and external folks that you know have a CNDA in place.
The Community site offers a Private Messaging service that you can use for secured communications. Just click on your avatar picture and select 'Messages'.
Just saying,
LFan
Hi Scott, Thanks for the tip! This is good to know. I have not shared anything confidential here yet but was wondering what's the right way to share.
Hi Zul:
Just to confirm, are you from Intel? The developers who you will pass the files to are also Intel employees, right? I could not seem to find you by searching your icon name in the Messages. What's the name I should search for?
Maybe we can exchange Intel emails to share the files?
Zulkifli_Intel
Hi LFan.
Yes, the developers are from Intel. Here is my email address:
zulkiflix.bin.abdul.halim@intel.com
Zul
Zulkifli_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
