I try to make a experiment of implementing "multitask" network on Myraid X, but I get the wrong output. Following are my steps to get the incorrect output.
I use an age classification implemented on Caffe as my experiment which contains the prototxt and weights.
I also upload the modified prototxt and caffemodel.
I made some modification of the prototxt by copying the last fc layer 'fc8' as following to create a two tasks network,
layers {
type: INNER_PRODUCT
bottom: "fc7"
top: "fc8"
inner_product_param {
num_output: 8
layers {
type: SOFTMAX
bottom: "fc8"
top: "prob"
layers {
type: INNER_PRODUCT
bottom: "fc7"
top: "copy_fc8"
num_output: 8
layers {
type: SOFTMAX
bottom: "copy_fc8"
top: "copy_prob"
Then I make the weights of above layer 'fc8' and 'copy_fc8' same, therefore, I should get the sample output from these two softmax output.
My input image is downloaded from google image search.
1.
I use model optimizer of R4 to convert the caffe model to get IR model and run it on Myraid 2.
I get the two same outputs of the input image as expectation,
copy_fc8: [ INFO ] ------- [ INFO ] 0.000357389 [ INFO ] 0.00239372 [ INFO ] 0.0594482 [ INFO ] 0.0129318 [ INFO ] 0.273193 [ INFO ] 0.260742 [ INFO ] 0.0244904 [ INFO ] 0.366211 fc8: [ INFO ] ------- [ INFO ] 0.000357389 [ INFO ] 0.00239372 [ INFO ] 0.0594482 [ INFO ] 0.0129318 [ INFO ] 0.273193 [ INFO ] 0.260742 [ INFO ] 0.0244904 [ INFO ] 0.366211
2.
I use model optimizer of R4 to convert the caffe model to get IR model and run it on Myraid X.
I get the two different outputs of the input image and the output from 'copy_fc8' seems correct which is similar to the experiment 1.,
copy_fc8: [ INFO ] ------- [ INFO ] 0.00031805 [ INFO ] 0.00197792 [ INFO ] 0.0588989 [ INFO ] 0.0136337 [ INFO ] 0.271484 [ INFO ] 0.260742 [ INFO ] 0.0244141 [ INFO ] 0.368896 fc8: [ INFO ] ------- [ INFO ] 0.0452271 [ INFO ] 0.039978 [ INFO ] 0.0336609 [ INFO ] 0.108032 [ INFO ] 0.300049 [ INFO ] 0.322998 [ INFO ] 0.10144 [ INFO ] 0.0483398
3.
I use model optimizer of R5 to convert the caffe model to get IR model and run it on Myraid 2.
I also get the two same outputs of the input image as expectation,
4.
I use model optimizer of R5 to convert the caffe model to get IR model and run it on Myraid X.
I also get the two different outputs of the input image and all outputs are different from the experiment 2.,
copy_fc8: [ INFO ] ------- [ INFO ] 0.00029707 [ INFO ] 0.000290632 [ INFO ] 0.00393295 [ INFO ] 0.0123291 [ INFO ] 0.0689697 [ INFO ] 0.652832 [ INFO ] 0.0205231 [ INFO ] 0.240723 fc8: [ INFO ] ------- [ INFO ] 0.0509949 [ INFO ] 0.0478516 [ INFO ] 0.0298309 [ INFO ] 0.104431 [ INFO ] 0.28833 [ INFO ] 0.334717 [ INFO ] 0.0968628 [ INFO ] 0.046936
Why did I get the different outputs when I run the model of R4 or R5 on Myraid X?
It seems that the problem is incurred by Myraid X since the output looks fine on Myraid 2 no matter what the API version is.
