6593 Discussions
Not Implemented Error: Some layers are not supported on the device
EddieChen
I am trying running the face detection sample on two different computer using CPU.
I've verified notebook can run the sample code .
Notebook hardware:
CPU i7-9750
Desktop computer hardware:
CPU i3-6100
I changed to desktop computer, an error had shown up.
"Not Implemented Error: Some layers are not supported on the device"
I am not sure is the new version of openvino is not supported to the old generation core?
And I found the parser in the sample code.
infer.add_argument('-l', '--cpu_lib', metavar="PATH", default="", help="(optional) For MKLDNN (CPU)-targeted custom layers, if any. " "Path to a shared library with custom layers implementations")
 What kind of library should I use or any other similar library?
Eddie
IntelSupport
Community Manager
Hi Eddie,
Thank you for updating your Github. I am able to run your sample code by doing small changes in your ie_module.py line 33 from ' if device == "CPU": ' into ' if device == "GPU": '. I think your code might be pointing to the incorrect plugin. Please recheck and update me with the result.
Aznie
IntelSupport
Community Manager
Hi Eddie,
Could you please verify the OpenVINO Toolkit installation by running the verification application on the CPU? There are two samples which are demo_squeezenet_download_convert_run.bat and demo_security_barrier_camera.bat. Check out the following link for more information.
https://docs.openvinotoolkit.org/latest/openvino_docs_install_guides_installing_openvino_windows.html
Please try and come back to us with the result.
Aznie
EddieChen
Dear Aznie,
I've verified the verification applications on the CPU.
Two sample applications are running well.
I just want to use two different versions of Openvino, to verify my own code.
In Openvino version 2021.R1, this error message was shown on the terminal.
But, on the Openvino version 2020.R4 running well.
I've tried to use different ".xml" and ".bin" file for different Openvino version.
My test result, use my own code:
Application version :
Python = 3.7.9
CMake = 3.14
Visual studio = 2019
Hardware info:
CPU = Intel i3-6100
Eddie
IntelSupport
Community Manager
Hi Eddie,
Could you please share your application or models you are using for us to duplicate this case?
Aznie
EddieChen
Dear Aznie,
Application show as below:
#!/usr/bin/env python
# coding: utf-8
import logging as log
import os
import os.path as osp
import sys
import cv2
import numpy as np
import time
from openvino.inference_engine import IECore, IENetwork
from face_detector import FaceDetector
from argparse import ArgumentParser
from ie_module import InferenceContext
#from video import creat_capture
#import monitors
model_xml = r"C:\Users\test\Desktop\Thermal_python\face-detection-0200\FP32\face-detection-0200.xml"
DEVICE_KINDS = ['CPU', 'GPU', 'FPGA', 'MYRIAD', 'HETERO', 'HDDL']
def build_argparser():
    parser = ArgumentParser()
    general = parser.add_argument_group('General')
    general.add_argument('-i', '--input', metavar="PATH", default='0', help="(optional) Path to the input video " "('0' for the camera, default)")
    general.add_argument('-o', '--output', metavar="PATH", default="", help="(optional) Path to save the output video to")
    general.add_argument('-tl', '--timelapse', action='store_true', help="(optional) Auto-pause after each frame")
    general.add_argument('--no_show', action='store_true', help="(optional) Do not display output")
    general.add_argument('-cw', '--crop_width', default=0, type=int, help="(optional) Crop the input stream to this width " "(default: no crop). Both -cw and -ch parameters " "should be specified to use crop.")
    #gallery.add_argument('--run_detector', action='store_true', help="(optional) Use Face Detection model to find faces" " on the face images, otherwise use full images.")
    models = parser.add_argument_group('Models')
    #models.add_argument('-m', metavar="PATH", default="", required=True, help="Path to the Face Detection model XML file")
    models.add_argument('-fd_iw', '--fd_input_width', default=0, type=int, help="(optional) specify the input width of detection model " "(default: use default input width of model). Both -fd_iw and -fd_ih parameters " "should be specified for reshape.")
    models.add_argument('-fd_ih', '--fd_input_height', default=0, type=int, help="(optional) specify the input height of detection model " "(default: use default input height of model). Both -fd_iw and -fd_ih parameters " "should be specified for reshape.")
    infer = parser.add_argument_group('Inference options')
    infer.add_argument('-d', default='CPU', choices=DEVICE_KINDS, help="(optional) Target device for the " "Face Detection model (default: %(default)s)")
    infer.add_argument('-d_fd', default='CPU', choices=DEVICE_KINDS, help="(optional) Target device for the " "Face Detection model (default: %(default)s)")
    infer.add_argument('-c', '--gpu_lib', metavar="PATH", default="", help="(optional) For clDNN (GPU)-targeted custom layers, if any. " "Path to the XML file with descriptions of the kernels")
    infer.add_argument('-v', '--verbose', action='store_true', help="(optional) Be more verbose")
    infer.add_argument('-pc', '--perf_stats', action='store_true', help="(optional) Output detailed per-layer performance stats")
    infer.add_argument('-t', metavar='[0..1]', type=float, default=0.4, help="(optional) Probability threshold for face detections" "(default: %(default)s)")
    infer.add_argument('--allow_grow', action='store_true', help="(optional) Allow to grow faces gallery and to dump on disk. " "Available only if --no_show option is off.")
    return parser
class FrameProcessor:
    QUEUE_SIZE = 16
    def __init__(self, args):
        used_devices = set([args.d])
        self.context = InferenceContext(used_devices, args.cpu_lib, args.gpu_lib, args.perf_stats)
        context = self.context
        log.info("Loading models")
        face_detector_net = self.load_model(model_xml)
        assert (args.fd_input_height and args.fd_input_width) or (args.fd_input_height==0 and args.fd_input_width==0), \
            "Both -fd_iw and -fd_ih parameters should be specified for reshape"
        if args.fd_input_height and args.fd_input_width :
            face_detector_net.reshape({"data": [1, 3, args.fd_input_height,args.fd_input_width]})
        self.face_detector = FaceDetector(face_detector_net,confidence_threshold = args.t)
        self.face_detector.deploy(args.d_fd, context)
        log.info("Models are loaded")
        self.allow_grow = args.allow_grow and not args.no_show
    def load_model(self, model_path):
        model_path = osp.abspath(model_path)
        model_weights_path = osp.splitext(model_path)[0] + ".bin"
        log.info("Loading the model from '%s'" % (model_path))
        assert osp.isfile(model_path), "Model description is not found at '%s'" % (model_path)
        assert osp.isfile(model_weights_path), "Model weights are not found at '%s'" % (model_weights_path)
        model = self.context.ie_core.read_network(model_path, model_weights_path)
        log.info("Model is loaded")
        return model
    def process(self, frame):
        assert len(frame.shape) == 3, "Expected input frame in (H, W, C) format"
        assert frame.shape[2] in [3, 4], "Expected BGR or BGRA input"
        orig_image = frame.copy()
        frame = frame.transpose((2, 0, 1)) # HWC to CHW
        frame = np.expand_dims(frame, axis=0)
        self.face_detector.clear()
        self.face_detector.start_async(frame)
        rois = self.face_detector.get_roi_proposals(frame)
        if self.QUEUE_SIZE < len(rois):
            log.warning("Too many faces for processing." " Will be processed only %s of %s." % (self.QUEUE_SIZE, len(rois)))
            rois = rois[:self.QUEUE_SIZE]
        outputs = [rois]
        return outputs
    def get_performance_stats(self):
        stats = {
            'face_detector': self.face_detector.get_performance_stats(),
        return stats
class Visualizer:
    BREAK_KEY_LABELS = "q(Q) or Escape"
    BREAK_KEYS = {ord('q'), ord('Q'), 27}
        self.frame_processor = FrameProcessor(args)
        self.display = not args.no_show
        self.print_perf_stats = args.perf_stats
        self.frame_time = 0
        self.frame_start_time = time.perf_counter()
        self.fps = 0
        self.frame_num = 0
        self.frame_count = -1
        self.input_crop = None
        if args.crop_width and args.crop_height:
            self.input_crop = np.array((args.crop_width, args.crop_height))
        self.frame_timeout = 0 if args.timelapse else 1
    def update_fps(self):
        now = time.perf_counter()
        self.frame_time = max(now - self.frame_start_time, sys.float_info.epsilon)
        self.fps = 1.0 / self.frame_time
        self.frame_start_time = now
    def draw_text_with_background(self, frame, text, origin, font=cv2.FONT_HERSHEY_SIMPLEX, scale=1.0, color=(0, 0, 0), thickness=1, bgcolor=(255, 255, 255)):
        text_size, baseline = cv2.getTextSize(text, font, scale, thickness)
        #cv2.rectangle(frame, tuple((origin + (0, baseline)).astype(int)), tuple((origin + (text_size[0], -text_size[1])).astype(int)), bgcolor, cv2.FILLED)
        cv2.putText(frame, text, tuple(origin.astype(int)), font, scale, color, thickness)
        return text_size, baseline
    def draw_detection_roi(self, frame, roi):
        for ovale in roi:
            sx,sy = ovale.position
            sw,sh = ovale.size
            if sx != 0 and sy != 0 and sw != 0 and sh != 0:
                pass
            print(ovale.position[0])
            print(ovale.position)
            #eddie
            cv2.rectangle(frame, tuple(ovale.position), tuple(ovale.position + ovale.size), (0, 220, 0), 2)
    def draw_detections(self, frame, detections):
        for roi in zip(*detections):
            self.draw_detection_roi(frame, roi)
    def draw_status(self, frame, detections):
        origin = np.array([15, 15])
        color = (0, 0, 255)
        font = cv2.FONT_HERSHEY_SIMPLEX
        text_scale = 0.5
        text_size, _ = self.draw_text_with_background(frame, "Frame time: %.3fs" % (self.frame_time), origin, font, text_scale, color)
        self.draw_text_with_background(frame, "FPS: %.1f" % (self.fps), (origin + (0, text_size[1] * 1.5)), font, text_scale, color)
        log.debug('Frame: %s/%s, detections: %s, ' 'frame time: %.3fs, fps: %.1f' % (self.frame_num, self.frame_count, len(detections[-1]), self.frame_time, self.fps))
        if self.print_perf_stats:
            log.info('Performance stats:')
            log.info(self.frame_processor.get_performance_stats())
    #def combine_frame(self):
    def display_interactive_window(self, frame):
        color = (255, 255, 255)
        text_scale = 0.5
        text = "Press '%s' key to exit" % (self.BREAK_KEY_LABELS)
        thickness = 2
        text_size = cv2.getTextSize(text, font, text_scale, thickness)
        origin = np.array([frame.shape[-2] - text_size[0][0] - 10, 10])
        line_height = np.array([0, text_size[0][1]]) * 1.5
        cv2.putText(frame, text, tuple(origin.astype(int)), font, text_scale, color, thickness)
        frame = cv2.resize(frame, (640, 480))
        cv2.imshow('Face recognition demo', frame)
    def should_stop_display(self):
        key = cv2.waitKey(self.frame_timeout) & 0xFF
        return key in self.BREAK_KEYS
    def process(self, input_stream, output_stream):
        self.input_stream = input_stream
        self.output_stream = output_stream
        while input_stream.isOpened():
            has_frame, frame = input_stream.read()
            if not has_frame:
                break
            if self.input_crop is not None:
                frame = Visualizer.center_crop(frame, self.input_crop)
            detections = self.frame_processor.process(frame)
            self.draw_detections(frame, detections)
            self.draw_status(frame, detections)
            if output_stream:
                output_stream.write(frame)
            if self.display:
                self.display_interactive_window(frame)
                if self.should_stop_display():
                    break
            self.update_fps()
            self.frame_num += 1
    @staticmethod
    def center_crop(frame, crop_size):
        fh, fw, fc = frame.shape
        crop_size[0] = min(fw, crop_size[0])
        crop_size[1] = min(fh, crop_size[1])
        return frame[(fh - crop_size[1]) // 2 : (fh + crop_size[1]) // 2,
                     (fw - crop_size[0]) // 2 : (fw + crop_size[0]) // 2, :]
    def run(self, args):
        input_stream = Visualizer.open_input_stream(args.input)
        if input_stream is None or not input_stream.isOpened():
            log.error("Cannot open input stream: %s" % args.input)
        fps = input_stream.get(cv2.CAP_PROP_FPS)
        frame_size = (int(input_stream.get(cv2.CAP_PROP_FRAME_WIDTH)), int(input_stream.get(cv2.CAP_PROP_FRAME_HEIGHT)))
        self.frame_count = int(input_stream.get(cv2.CAP_PROP_FRAME_COUNT))
            crop_size = (args.crop_width, args.crop_height)
            frame_size = tuple(np.minimum(frame_size, crop_size))
        log.info("Input stream info: %d x %d" % (frame_size[0], frame_size[1]))
        output_stream = Visualizer.open_output_stream(args.output, frame_size)
        self.process(input_stream, output_stream)
        # Release resources
        if output_stream:
            output_stream.release()
        if input_stream:
            input_stream.release()
        cv2.destroyAllWindows()
    @staticmethod
    def open_input_stream(path):
        log.info("Reading input data from '%s'" % (path))
        stream = path
        try:
            stream = int(path)
        except ValueError:
            pass
        return cv2.VideoCapture(stream)
    @staticmethod
    def open_output_stream(path, frame_size):
        output_stream = None
        if path != "":
            if not path.endswith('.avi'):
                log.warning("Output file extension is not 'avi'. " "Some issues with output can occur, check logs.")
            log.info("Writing output to '%s'" % (path))
            output_stream = cv2.VideoWriter(path, cv2.VideoWriter.fourcc(*'MJPG'), 30, frame_size)
        return output_stream
def main():
    args = build_argparser().parse_args()
    log.basicConfig(format="[ %(levelname)s ] %(asctime)-15s %(message)s", level=log.INFO if not args.verbose else log.DEBUG, stream=sys.stdout)
    log.debug(str(args))
    visualizer = Visualizer(args)
    visualizer.run(args)
if __name__ == '__main__':
    main()
By the way, I've tried to use two different models, face_detection_0100 and face_detection_0200.
Eddie
Aznie_Intel
Hi Eddie,
We got an import module error when trying to duplicate your case. Could you please share all related files of the application? You can share all the documents in a zip file or GitHub link for us the clone your project and test in our machine.
Aznie
EddieChen
Dear Aznie,
About the code, please see the attached.
Face_detection
Eddie
IntelSupport
Community Manager
Hi Eddie,
From your Github, there is no utils.py file which leads us to an import module error. Can you provide the files and please clarify what package contains the resize_input function as yours is not part of utils-1.0.1. Also, kindly share the command you use to run your sample code.
Aznie
EddieChen
Dear Aznie,
Pleas see the README file, i also uploaded the utils.py to github.
About this, I don't understand what mean is it.
Thank you for your reply!
Eddie
IntelSupport
Community Manager
Hi Eddie,
Aznie
EddieChen
Dear Aznie,
The face-detection application can run well now.
This application is downloaded from the Open-model-zoo github, I never thought it have erred.
I appreciate you help me to solve the question!
Eddie
IntelSupport
Community Manager
Hi Eddie,
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Aznie
