OPENVINO ERROR!
DEEPAK1_R_Intel
“[ WARNING ] Model Optimizer removes the pre-processing block of the model which resizes image keeping aspect ratio. The Inference Engine does not support dynamic image size so the Intermediate Representation file is generated with the input image size of a fixed size.
Specify the "--input_shape" command line parameter to override the default shape which is equal to (600, 600).
The Preprocessor block has been removed. Only nodes performing mean value subtraction and scaling (if applicable) are kept.
[ ERROR ]  Exception occurred during running replacer "ObjectDetectionAPIDetectionOutputReplacement" (<class 'extensions.front.tf.ObjectDetectionAPI.ObjectDetectionAPIDetectionOutputReplacement'>): Found the following nodes '[]' with name 'proposals' but there should be exactly 1. Looks like ObjectDetectionAPIProposalReplacement replacement didn't work.”
Any suggestion to solve this error?
Shubha_R_Intel
Dear R, DEEPAK1,
I'm assuming your model is custom trained ? Please see my answer to this post
shubha
