OPENVINO WITH CYCLONE 5 FPGA
MMoha9
Hello, i was trying do test inference engine with cyclone 5 fpga on the starterkit openvino (C5P <=>OSK ).
when i tried to do the inference on fpga : i got this error:
root@UP2:/opt/intel/2019_r1/openvino/deployment_tools/terasic_demo/demo# ./02_security_barrier.sh fpga
target_device = HETERO:FPGA,CPU
target_precision = FP16
Build Inference Engine samples
[ INFO ] InferenceEngine:
   API version ............ 1.6
   Build .................. custom_releases/2019/R1_c9b66a26e4d65bb986bb740e73f58c6e9e84c7c2
[ INFO ] Parsing input parameters
[ INFO ] Capturing video streams from the video files or loading images
[ INFO ] Files were added: 1
[ INFO ]    /opt/intel/2019_r1/openvino/deployment_tools/terasic_demo/demo/pic_video/car_barrier.bmp
[ INFO ] Number of input image files: 1
[ INFO ] Number of input video files: 0
[ INFO ] Number of input channels: 1
[ INFO ] Display resolution: 1920x1080
[ INFO ] Loading plugin HETERO:FPGA,CPU
   Build .................. heteroPlugin
   Description ....... heteroPlugin
[ INFO ] Loading plugin CPU
   Build .................. 22443
   Description ....... MKLDNNPlugin
[ INFO ] Loading network files for VehicleDetection
[ INFO ] Batch size is forced to 1
[ INFO ] Checking Vehicle Detection inputs
[ INFO ] Checking Vehicle Detection outputs
[ INFO ] Loading Vehicle Detection model to the HETERO:FPGA,CPU plugin
terminate called after throwing an instance of 'dla::error'
i fact, the board is only connected to laptop using JTAG cable , there is not PCIe connection.
so anyone have any suggestions about this error?
should i connect the board with PCIe slot to the host to do inference?
thanks in advance
Shubha_R_Intel
Dear
Oussayran, Mohamad,
At minimum you will require an OpenCL BSP that can communicate with the board. Cyclone5 is not one of the platforms we officially support.
Hope it helps,
Shubha
MMoha9
hello,
thank you for your answer.
About the BSP, I already downloaded the BSO from terasic website. but what I want to know is:
1- should I connect the board to a PCIe slot ? to load the bitstream
2- which Altera OpenCL version should I use? and do I need a license?  I already downloaded the 17.1 which is the intel OpenCL SDK
3- if i download the altera opencl SDK, it should work normally with the openvino toolkit 2019.1 r1 for the cyclone 5 ?
