OPenVino Windows10 Installation Query
Lawton__John
Hi  I am trying to install OPenVino and have reached the step where
 w_openvino_toolkit_p_<version>.exe is available. Double click causes
the install to run but 1) C:/Intel is not established as per documentation though they are written
to another default location.
2) I cannot locate the model optimiser  mo.py file
3) the ' .msi'  files state that Setup.exe is required to launch the install?
In short it looks as though a 'last phase' of installation does not happen.
Comments very much Appreciated
NB All stated dependencies were loaded OK before the Openvino install was executed.
Joel_E_
Hi John,
Have you tried checking the following document: OpenVino Installation on Windows
There are some core components you might need to install too. Those steps are provided in the document.
Joel
Lawton__John
Thank you for your reply. YES indeed I have worked through the steps you mention and all installed OK.
For the OpenVino part the installation does not appear to complete with no errors reported
Thanks again
       Stewart
RBang
New Contributor II
If C:/Intel is not available, is not created while running the setup? If not, try pointing it to a different directory. In my case I didn't want it to be installed in the default directory and so pointed it to a new one and it went as expected.
If this step is not completed properly you'll never be able to access mo.py which is installed inside that directory -\deployment_tools\model_optimizer\mo.py
I'm unsure about the Setup.exe bit. I simply downloaded the setup, extracted it and ran the install application.
nikos1
Valued Contributor I
What is the OS version?
Could it be that there is not enough space in the main drive?
Could you try
.\w_openvino_toolkit_p_2018.4.420.exe  --x
and the run install.exe from the folder where OpenVino was extracted?
Cheers,
Nikos
