6586 Discussions
Object Detection CPP sample failed to compile yolo v8 model
ChrisChang
I'm trying to use the Object Detection CPP sample from Model Zoo.
(OpenVino ver. 2025.2)
(see https://github.com/openvinotoolkit/open_model_zoo/tree/master/demos/object_detection_demo/cpp
It works well for loading the models in the models.lst.
Now I got a fine-tuned AI model based on Yolo V8, it works well with my own Python script.
And I'd like to to do this with CPP sample code (https://github.com/openvinotoolkit/open_model_zoo/tree/master/demos/object_detection_demo/cpp).
But I encounter the exception while thr code ran into the function
"logBasicModelInfo" in "common.hpp",
The exception occurs at
"const std::string name = output.get_any_name();"
Looks some kinds of NULL when loading info from ov::Output.
What can I do for adding the required information into model?
Or should I modify the OpenVino library?
Zulkifli_Intel
Hi ChrisChang.
To integrate a custom model with Open Model Zoo Demos, you need to modify the demo's source code to fit your model. It is better to use a minimal C++ example to start. Therefore, I suggest you refer to the YOLOv8 OpenVINO Inference in C++
Zul
Zulkifli_Intel
Hi ChrisChang,
Could you please share your YOLOv8 model so I can take a look at the issue further?
Zul
ChrisChang
Hi Zul:
Thaks for your reply.
Pls find the attachment.
ChrisChang
Hi:
Any update?
Zulkifli_Intel
Hi ChrisChang.
Zul
ChrisChang
Thanks, it's work for me.
Zulkifli_Intel
This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
