Object_detection_SSD sample error
Morishige__Akihito
Hi, When I run the object_detection_SSD_sample, error is occured as follows.
[ ERROR ] Can't find output layer named bbox_pred
I don't know what should I do in this situation.
I used VOC0712_SSD300 to convert the IR model. I attached .xml file iused.
Severine_H_Intel
Dear Morishige,
can you confirm that you ran the sample: object_detection_sample_ssd? The error you show is more typical from the sample: object_detection_sample​ which expects a layer called ​bbox_pred.
Best,
Severine
Morishige__Akihito
Thanks for reply. I can't  understand what [bbox_pred] means.
So what should I revise ? Where the typical bbox error occur ?
I ran the sample as follows. There is a error.
1. Download SSD model (downloader.py doesn't work correctly)
2. Convert caffemodel and deploy.prototxt to .xml by using model optimizer.
3. I ran the object_detection_ssd samle by using xml.
Severine_H_Intel
Dear Morishige,
I would like to reproduce your error, can you send me the link to the original model (if you took it from the internet)? Or add the .bin to the zip file along with the xml?
Best,
Severine
Morishige__Akihito
I mistook the command. Sample run correctly.
Error was not object_detection_sample_ssd but object_detection_sample as you said.
Thank you for replying many times.
