Open Vino Demo fails building
RTasa
Build Inference engine samples using Visual Studio (MSBuild.exe) error C3861: ...softmax.h _mm_blendv.ps : identifier not found [... ie_cpu_extension.vcxproj]
nikos1
Valued Contributor I
What version of Visual Studio are you using?
Any issues from cmake?
RTasa
VS 2017 Windows 10 . Building before that seemed smooth. My Laptop for this is not the latest would that have anything to do with the build of the demo?
nikos1
Yes could be related to an old CPU that does not support some SSE instruction.
What is the CPU model? Could you try on a more recent system?
Just found this that looks relevant (?)
https://medium.com/developerofstuff/openvino-mm-blendv-ps-build-error-bdc37855ac04
Maybe try to edit C:\Intel\computer_vision_sdk_2018.4.420\deployment_tools\inference_engine\src\extension\common\defs.h
#if defined (HAVE_SSE) || defined (HAVE_AVX2)
#if defined (_WIN32)
// #include <emmintrin.h>
#include <smmintrin.h>
#else
#include <x86intrin.h>
#endif
#endif
RTasa
I just downloading and installing CPU-Z and found out I have an i 5 Ivy Bridge which supports SSE 4.2 So I am going to change the DEF file and see what happens.
RTasa
SUCCESS with a car and plate detected. Unless it was faked this is cool. Thanks so so much. I tried searching for the error cut did not find the blog post.
nikos1
Good to know!  Not faked.. :-) I tried on other clips too. The pre-trained OpenVino models are pretty accurate for Chinese cars/plates.
Cheers,
Nikos
RTasa
The other sample made me feel OK I got a 38.x fps inference which is very decent. Feels like I have so much to learn I did some Tensorflow before now trying this with Movidius Stick version 2
