Open Vino License
Oniel
We are considering using OPEN Vino and the pre-trained models that come along for a commercial project.
I would like to know weather Open vino is free for use on a commercial project.
We also plan on using the pretrained models available at
Would also like to know if the pretrained models can be deployed for a commercial project.
https://software.intel.com/content/www/us/en/develop/tools/openvino-toolkit/pretrained-models.html
Max_L_Intel
Hi @Oniel
Open Model Zoo pre-trained models are distributed through Apache 2.0 open-source license: https://github.com/openvinotoolkit/open_model_zoo/blob/master/LICENSE
OpenVINO toolkit components are available via EULA (in case of using Intel Distribution) and open-source Apache 2.0 (open source distribution).
Thank you.
Best regards, Max.
Max_L_Intel
Hello @Oniel
We are still looking into your question and come back to you soon.
samontab
Valued Contributor II
I'll start by saying this is not legal advice, and you should contact a professional in these legal areas to help you.
As stated on their github repository, OpenVINO is released under the Apache License 2.0
A permissive license whose main conditions require preservation of copyright and license notices. Contributors provide an express grant of patent rights. Licensed works, modifications, and larger works may be distributed under different terms and without source code.
You can clearly see from that link that this license allows commercial use.
The provided pre-trained models are available from the OpenVINO™ Toolkit - Open Model Zoo repository, which has the same Apache License 2.0.
Intel is encouraging the use of these models:
Use these free pre-trained models instead of training your own models to speed-up the development and production deployment process.
Max_L_Intel
Hi @Oniel
Thank you.
Best regards, Max.
Max_L_Intel
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
