6594 Discussions
OpenCV has generated an error with code -2 with message > Failed to initialize Inference Engine back
Demiray__Baris
Hello all,
I am trying to build a test app using OpenCV 4.4 with OpenVINO 2020.4 but when I try to load the model I'm having the error below. I'm quite stuck on this as the search doesn't return much with this error message. Thanks in advance!
OpenCV has generated an error with code -2 with message > Failed to initialize Inference Engine backend (device = GPU): Program build failed:
> 14:31707:79: warning: use of logical '||' with constant operand
> if (
xy * X_BLOCK_SIZE + X_BLOCK_SIZE <= OUTPUT_SIZE_X * OUTPUT_SIZE_Y || (OUTPUT_SIZE_X * OUTPUT_SIZE_Y) % X_BLOCK_SIZE == 0) {
> 14:31707:79: note: use '|' for a bitwise operation
> if (xy * X_BLOCK_SIZE + X_BLOCK_SIZE <= OUTPUT_SIZE_X * OUTPUT_SIZE_Y || (OUTPUT_SIZE_X * OUTPUT_SIZE_Y) % X_BLOCK_SIZE == 0) {
> 14:36774:47: warning: use of logical '||' with constant operand
> if (x + X_BLOCK_SIZE <= OUTPUT_SIZE_X || OUTPUT_SIZE_X % X_BLOCK_SIZE == 0
> 14:36774:47: note: use '|' for a bitwise operation
> if (x + X_BLOCK_SIZE <= OUTPUT_SIZE_X || OUTPUT_SIZE_X % X_BLOCK_SIZE == 0) {
> 14:36777:13: error: too few elements in vector initialization (expected 8 elements, have 2)
> FUSED_OPS_VEC;
> 14:33881:2: note: expanded from macro
'FUSED_OPS_VEC'
> FUSED_OP0_ACTION_VEC
> 14:33878:59: note: expanded from macro 'FUSED_OP0_ACTION_VEC'
> dst_out = ACTIVATION_FUNC_FUSED_OP0_VEC(dst_out, (float8)(0,000000),(float8)(6,000000));
> 14:33881:2: note: expanded from macro 'FUSED_OPS_VEC'
> 14:33878:78: note: expan
> 14:36796:17: warning: expres
sion result unused
> FUSED_OPS_SCALAR;
> 14:33910:2: note: expanded from macro 'FUSED_OPS_SCALAR'
> FUSED_OP0_ACTION_SCALAR
> 14:33907:68: note: expanded from mac
ro 'FUSED_OP0_ACTION_SCALAR'
> dst_i__out = ACTIVATION_FUNC_FUSED_OP0_SCALAR(dst_i__out, (float)(0,000000),(float)(6,000000));
> 14:33903:98: note: expanded from macro '
ACTIVATION_FUNC_FUSED_OP0_SCALAR'
> #define ACTIVATION_FUNC_FUSED_OP0_SCALAR(input, m, n) (ACTIVATION_FUNC_FUSED_OP0_SCALAR_MAX_FUNC(m, (ACTIVATION_FUNC_FUSED_OP0_SCALAR_MIN_FUNC(n, input))))
Demiray__Baris
Maksim_S_Intel
Looks like a problem with OpenCL kernel compilation. It is impossible to say more without any details: platform, OpenCL runtime, DL-model, reproducer app.
Demiray__Baris
Hi Maksim,
Thanks a lot for your response. Here are some more details. I attached the outputs of following commands on my Ubuntu 18.04.5 LTS (Bionic Beaver) system.
  • clinfo
  • lshw -c display
Reproducer app is just doing
    1) cv::dnn::readNetFromModelOptimizer
    2) enableFusion(true)
    3) setPreferableBackend(DNN_BACKEND_INFERENCE_ENGINE)
    4) setPreferableTarget(DNN_TARGET_OPENCL);
    5) forward()
and it's crashing at the forward() step, i.e. the first inference where I guess it initiates the OpenCL compilation.
Model is the one from the OpenVINO repository, person-detection-0102, the FP32 version.
Since I don't have any idea on what might be going wrong, could you point me to possible reasons of this? Driver? Memory? Possible clash of library linkage?
Thanks a lot!
Maksim_S_Intel
It needs more investigation, but for now I can say that "readNetFromModelOptimizer" passes network directly to InferenceEngine and is mostly equivalent to direct usage of InferenceEngine. "enableFusion" should not affect it. Did you try to execute this model with one of native InferenceEngine samples or demos? Maybe this one: https://docs.openvinotoolkit.org/2020.4/openvino_inference_engine_samples_object_detection_sample_ssd_README.html?
Demiray__Baris
Hi Maksim,
Thanks a lot for the response. After a few days of tests it disappeared even though we were using the same OS image on the same machine. So I still don't know what the problem was and I can reproduce. I'll consider it case closed.
Thanks again. Have a great day.
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Sincerely,
Iffa
