OpenCV with VAAPI video capture support .
sg
Wondering how to enable VAAPI (e.g. iHD driver)  in OpenCV to do video capture (e.g. cv::VideoCapture  ) ?  Any pointers will be appreciated.
Maksim_S_Intel
Currently the only way is to use GStreamer backend (change avidemux element according to your container):
VideoCapture cap(
    "filesrc location=<filename> ! avidemux ! vaapidecodebin ! appsink",
    CAP_GSTREAMER);
You can read more here: https://github.com/opencv/opencv/wiki/Video-capture-and-write-benchmark
sg
Thanks Maksim,  wondering if  the same  video decoding acceleration in OpenCV can also be achieved through the Intel MediaSDK ?  The following option is there OpenCV.
CAP_INTEL_MFX
Python: cv.CAP_INTEL_MFX
Intel MediaSDK.
Maksim_S_Intel
Yes, it is possible: https://github.com/opencv/opencv/wiki/MediaSDK-encode-decode-backend
But this backend supports only raw video stream files and have limited number of parameters.
sg
Thanks,   lack of container support makes it much less useful for now.   That is a dead end for  what I am trying to do.  Is it possible to build an entire GEN9 (GPU) accelerated pipeline to  process  h.264 video in mpeg4 container   along the following line (with or without OpenCV , OpenCL is ok) ?
[RTSP, h.264/mpeg4] -> [decode] -> [ resize/transform] ->[low level computer vision, e.g. VME]->[CPU for high level computer vision]
If possible, would be great to have an idea of how to make that work .
