6590 Discussions
[OpenVINO 2020.03 LTS Problem on Hetero:FPGA,CPU] Implementation on FlowNetS model failed
yenfu9921132
[Problem on Hetero:FPGA,CPU] Implementation on FlowNetS model failed
I am trying to implement FlowNetS on Dev Cloud for Edge.
I can run inference on CPU/GPU/Hetero:GPU,CPU/VPU instead of Hetero:FPGA,CPU.
How can I solve this problem? I use a bitstream file from sample tutorial. If there is any unsupported layer, it should fall back to CPU right?.
Basically, the code stuck at this line -> net = ie.read_network(model=model_xml, weights=model_bin)
and error is -> /var/spool/torque/mom_priv/jobs/70397.v-qsvr-2.devcloud-edge.SC: line 35: 23932 Segmentation fault
I put my xml file in appendex
here is my qsub command
#Submit job to the queue
job_id_fpga = !qsub flownets.sh -l nodes=2:idc003a10 -F "results/fpga HETERO:FPGA,CPU FP16" -N Flownets_fpga
print(job_id_fpga[0])
#Progress indicators
if job_id_fpga:
progressIndicator('results/fpga', f'i_progress_{job_id_fpga[0]}.txt', "Inference", 0, 100)
Here is my job output:
# Date: Thu Feb 18 05:48:40 PST 2021
# Job ID: 70397.v-qsvr-2.devcloud-edge
# User: u60570
# Resources: neednodes=2:idc003a10,nodes=2:idc003a10,walltime=00:10:00
[setupvars.sh] OpenVINO environment initialized
INTELFPGAOCLSDKROOT is not set
Using script's current directory (/opt/altera/aocl-pro-rte/aclrte-linux64)
aoc was not found, but aocl was found. Assuming only RTE is installed.
AOCL_BOARD_PACKAGE_ROOT is set to /opt/intel/openvino/bitstreams/a10_vision_design_sg2_bitstreams/BSP/a10_1150_sg2. Using that.
Adding /opt/altera/aocl-pro-rte/aclrte-linux64/bin to PATH
Adding /opt/altera/aocl-pro-rte/aclrte-linux64/linux64/lib to LD_LIBRARY_PATH
Adding /opt/altera/aocl-pro-rte/aclrte-linux64/host/linux64/lib to LD_LIBRARY_PATH
Adding /opt/intel/openvino/bitstreams/a10_vision_design_sg2_bitstreams/BSP/a10_1150_sg2/linux64/lib to LD_LIBRARY_PATH
aocl program: Running program from /opt/intel/openvino/bitstreams/a10_vision_design_sg2_bitstreams/BSP/a10_1150_sg2/linux64/libexec
Programming device: a10gx_2ddr : Intel Vision Accelerator Design with Intel Arria 10 FPGA (acla10_1150_sg20)
Program succeed.
Imported Python modules successfully.
=> will save raw output and RGB visualization
=> fetching img pairs in './test/'
=> will save everything to ./test/flow
1 samples found
input_var shape torch.Size([1, 6, 384, 512])
[ INFO ] Initializing plugin for HETERO:FPGA,CPU device...
check
An Inference Engine object has been created
HETERO:FPGA,CPU
[ INFO ] Loading FlowNetS model to the plugin
[ INFO ] Loading network files:
models/FP16/saved_model.xml
models/FP16/saved_model.bin
# End of output for job 70397.v-qsvr-2.devcloud-edge
# Date: Thu Feb 18 05:49:23 PST 2021
sys.argv[0]=[/etc/collectd/telemetrySender.py]
sys.argv[1]=[u60570]
sys.argv[2]=[70397.v-qsvr-2.devcloud-edge]
sys.argv[3]=[42]
sys.argv[4]=[1613656122]
sys.argv[5]=[1613656164]
sys.argv[6]=[idc003a10_compnode_openvino-lts_intel-core_i5-6500te_intel-hd-530_ram8gb_arria10-fpga_tank-870_iei-mustang-f100-a10]
USER_ID=[u60570]
JOB_ID=[70397]
JOB_RUNTIME=[42]
FROM_TIME=[1613656122]
TO_TIME=[1613656164]
HOST_TYPE=[idc003a10_compnode_openvino-lts_intel-core_i5-6500te_intel-hd-530_ram8gb_arria10-fpga_tank-870_iei-mustang-f100-a10]
EDGE_NAME=[s003-n014]
PBS_O_WORKDIR=[/home/u60570/My-Notebooks/flownet]
APPLICATION_NAME=[flownet]
INTEL_SKU=[core-i5]
skipping application metrics
InfluxDBClient.write_points(metric_list) result_success:[True]
Here is my job error
0%| | 0/1 [00:00<?, ?it/s]
100%|██████████| 1/1 [00:00<00:00, 2.77it/s]/var/spool/torque/mom_priv/jobs/70397.v-qsvr-2.devcloud-edge.SC: line 35: 23932 Segmentation fault python3 flownet.py -IR $MODELPATH -r $OUTPUT_FILE -d $DEVICE
Here is my shell file
# Store input arguments: <output_directory> <device> <fp_precision>
OUTPUT_FILE=$1
DEVICE=$2
FP_MODEL=$3
# The default path for the job is the user's home directory,
# change directory to where the files are.
cd $PBS_O_WORKDIR
# Make sure that the output directory exists.
mkdir -p $OUTPUT_FILE
# Check for special setup steps depending upon device to be used
if [ "$DEVICE" = "HETERO:FPGA,CPU" ]; then
# Environment variables and compilation for edge compute nodes with FPGAs - Updated for OpenVINO 2020.3
export AOCL_BOARD_PACKAGE_ROOT=/opt/intel/openvino/bitstreams/a10_vision_design_sg2_bitstreams/BSP/a10_1150_sg2
source /opt/altera/aocl-pro-rte/aclrte-linux64/init_opencl.sh
aocl program acl0 /opt/intel/openvino/bitstreams/a10_vision_design_sg2_bitstreams/2020-3_PL2_FP16_MobileNet_Clamp.aocx
export CL_CONTEXT_COMPILER_MODE_INTELFPGA=3
fi
if [ "$DEVICE" = "HETERO:FPGA,GPU,CPU" ]; then
fi
# Set inference model IR files using specified precision
MODELPATH=models/${FP_MODEL}/saved_model
# Run the brain tumor segmentation code
python3 flownet.py -IR $MODELPATH \
-r $OUTPUT_FILE \
-d $DEVICE
Here is my code
import os
import time
import numpy as np
from openvino.inference_engine import IECore
from argparser import args
import torchvision.transforms as transforms
import flow_transforms
from path import Path
from tqdm import tqdm
from imageio import imread, imwrite
import torch
import logging as log
from matplotlib import pyplot as plt
from qarpo.demoutils import progressUpdate
global args, save_path
print('Imported Python modules successfully.')
import sys
import torch.nn.functional as F
import cv2
try:
except:
print("path not installed")
try:
except:
print("tqdm not installed")
try:
except:
print("imageio not installed")
if args.output_value == 'both':
output_string = "raw output and RGB visualization"
elif args.output_value == 'raw':
output_string = "raw output"
elif args.output_value == 'vis':
output_string = "RGB visualization"
print("=> will save " + output_string)
data_dir = Path(args.data)
print("=> fetching img pairs in '{}'".format(args.data))
if args.output is None:
save_path = data_dir/'flow'
else:
save_path = Path(args.output)
print('=> will save everything to {}'.format(save_path))
save_path.makedirs_p()
# Data loading code
input_transform = transforms.Compose([
flow_transforms.ArrayToTensor(),
transforms.Normalize(mean=[0,0,0], std=[255,255,255]),
transforms.Normalize(mean=[0.411,0.432,0.45], std=[1,1,1])
img_pairs = []
for ext in args.img_exts:
test_files = data_dir.files('*1.{}'.format(ext))
for file in test_files:
img_pair = file.parent / (file.stem[:-1] + '2.{}'.format(ext))
if img_pair.isfile():
img_pairs.append([file, img_pair])
print('{} samples found'.format(len(img_pairs)))
for (img1_file, img2_file) in tqdm(img_pairs):
img1 = input_transform(imread(img1_file))
img2 = input_transform(imread(img2_file))
input_var = torch.cat([img1, img2]).unsqueeze(0)
if args.bidirectional:
# feed inverted pair along with normal pair
inverted_input_var = torch.cat([img2, img1]).unsqueeze(0)
input_var = torch.cat([input_var, inverted_input_var])
print("input_var shape",input_var.shape)
def load_model(
Load the OpenVINO model.
log.info("Loading U-Net model to the plugin")
model_xml = args.intermediate_rep +".xml"
model_bin = args.intermediate_rep +".bin"
return model_xml, model_bin
log.basicConfig(format="[ %(levelname)s ] %(message)s", level=log.INFO, stream=sys.stdout)
# Plugin initialization for specified device and load extensions library if specified
log.info("Initializing plugin for {} device...".format(args.device))
print("check")
#plugin = IEPlugin(device=args.device, plugin_dirs=args.plugin_dir)
ie=IECore()
print("An Inference Engine object has been created")
print(args.device)
if args.cpu_extension and "CPU" in args.device:
#plugin.add_cpu_extension(args.cpu_extension)
ie.add_extension(args.cpu_extension, "CPU")
# Read IR
# If using MYRIAD then we need to load FP16 model version
model_xml, model_bin = load_model()
log.info("Loading network files:\n\t{}\n\t{}".format(model_xml, model_bin))
print("network loaded check!")
if args.device == "CPU":
supported_layers = ie.query_network(net, args.device)
not_supported_layers = [l for l in net.layers.keys() if l not in supported_layers]
if len(not_supported_layers) != 0:
log.error("Following layers are not supported by the plugin for specified device {}:\n {}".
format(args.device, ', '.join(not_supported_layers)))
log.error("Please try to specify cpu extensions library path in sample's command line parameters using -l "
"or --cpu_extension command line argument")
sys.exit(1)
assert len(net.inputs.keys()) == 1, "Sample supports only single input topologies"
assert len(net.outputs) == 1, "Sample supports only single output topologies"
Ask OpenVINO for input and output tensor names and sizes
input_blob = next(iter(net.inputs)) # Name of the input layer
out_blob = next(iter(net.outputs)) # Name of the output layer
print("name_output",out_blob)
batch_size, n_channels, height, width = net.inputs[input_blob].shape
batch_size, n_out_channels, height_out, width_out = net.outputs[out_blob].shape
net.batch_size = batch_size
print("batch_size is:",batch_size)
# Loading model to the plugin
exec_net = ie.load_network(network=net,device_name=args.device)
def flow2rgb(flow_map, max_value):
flow_map_np = flow_map
_, h, w = flow_map_np.shape
flow_map_np[:,(flow_map_np[0] == 0) & (flow_map_np[1] == 0)] = float('nan')
rgb_map = np.ones((3,h,w)).astype(np.float32)
if max_value is not None:
normalized_flow_map = flow_map_np / max_value
else:
normalized_flow_map = flow_map_np / (np.abs(flow_map_np).max())
rgb_map[0] += normalized_flow_map[0]
rgb_map[1] -= 0.5*(normalized_flow_map[0] + normalized_flow_map[1])
rgb_map[2] += normalized_flow_map[1]
return rgb_map.clip(0,1)
def print_stats(exec_net, input_data, n_channels, batch_size, input_blob, out_blob, args):
Prints layer by layer inference times.
Good for profiling which ops are most costly in your model.
# Start sync inference
print("Starting inference ({} iterations)".format(args.number_iter))
infer_time = []
for i in range(args.number_iter):
t0 = time.time()
print(input_data.shape)
res = exec_net.infer(inputs={input_blob: input_data})
infer_time.append((time.time() - t0))
average_inference = np.average(np.asarray(infer_time))
print("Average running time of one batch: {:.5f} ms".format(average_inference))
print("Images per second = {:.3f}".format(batch_size * 1000.0 / average_inference))
perf_counts = exec_net.requests[0].get_perf_counts()
log.info("Performance counters:")
log.info("{:<70} {:<15} {:<15} {:<15} {:<10}".format("name",
"layer_type",
"exec_type",
"status",
"real_time, us"))
for layer, stats in perf_counts.items():
log.info("{:<70} {:<15} {:<15} {:<15} {:<10}".format(layer,
stats["layer_type"],
stats["exec_type"],
stats["status"],
stats["real_time"]))
output = res[out_blob]
print(output.shape)
for suffix, flow_output in zip(['flow', 'inv_flow'], output):
filename = Path(args.results_directory)/'{}{}'.format(img1_file.stem[:-1], suffix)
Path(args.results_directory).makedirs_p()
if args.output_value in['vis', 'both']:
rgb_flow = flow2rgb(args.div_flow * flow_output, max_value=args.max_flow)
to_save = (rgb_flow * 255).astype(np.uint8).transpose(1,2,0)
imwrite(filename + '.png', to_save)
print("saving to..",filename + '.png')
if args.output_value in ['raw', 'both']:
# Make the flow map a HxWx2 array as in .flo files
to_save = (args.div_flow*flow_output).transpose(1,2,0)
np.save(filename + '.npy', to_save)
with open(os.path.join(png_directory, f'stats_{job_id}.txt'), 'w') as f:
f.write("{:.5f}\n".format(average_inference))
f.write("{}\n".format(args.number_iter))
f.write("Average running time of one batch: {:.5f} s\n".format(average_inference))
f.write("Images per second = {:.3f}".format(batch_size * 1.0 / average_inference))
job_id = os.environ['PBS_JOBID']
print(job_id)
png_directory = args.results_directory
if not os.path.exists(png_directory):
os.makedirs(png_directory)
args.stats = True
progress_file_path = os.path.join(png_directory,f"i_progress_{job_id}.txt")
process_time_start = time.time()
if args.stats:
# Print the latency and throughput for inference
print_stats(exec_net, input_var, n_channels, batch_size, input_blob, out_blob, args)
progressUpdate(progress_file_path, time.time()-process_time_start, 1, 1)
try:
import applicationMetricWriter
applicationMetricWriter.send_application_metrics(model_xml, args.device)
except:
print("applicationMetricWriter not installed")
Here is my good result from CPUs
# Date: Thu Feb 18 05:58:29 PST 2021
# Job ID: 70401.v-qsvr-2.devcloud-edge
# User: u60570
1 samples found
[ INFO ] Initializing plugin for CPU device...
check
CPU
name_output Conv_40
batch_size is: 1
Starting inference (60 iterations)
Average running time of one batch: 0.12851 ms
Images per second = 7781.442
[ INFO ] Performance counters:
[ INFO ] name layer_type exec_type status real_time, us
[ INFO ] Concat_24 Concat unknown_FP32 EXECUTED 3
[ INFO ] Concat_24_nchw_nChw8c_ConvTranspose_27 Reorder ref_any_FP32 EXECUTED 64
[ INFO ] Concat_24_nchw_nChw8c_Conv_25 Reorder ref_any_FP32 EXECUTED 65
[ INFO ] Concat_29 Concat unknown_FP32 EXECUTED 2
[ INFO ] Concat_29_nchw_nChw8c_ConvTranspose_32 Reorder ref_any_FP32 EXECUTED 163
[ INFO ] Concat_29_nchw_nChw8c_Conv_30 Reorder ref_any_FP32 EXECUTED 240
[ INFO ] Concat_34 Concat unknown_FP32 EXECUTED 3
[ INFO ] Concat_34_nchw_nChw8c_ConvTranspose_37 Reorder ref_any_FP32 EXECUTED 479
[ INFO ] Concat_34_nchw_nChw8c_Conv_35 Reorder ref_any_FP32 EXECUTED 573
[ INFO ] Concat_39 Concat unknown_FP32 EXECUTED 3
[ INFO ] Concat_39_nchw_nChw8c_Conv_40 Reorder ref_any_FP32 EXECUTED 1044
[ INFO ] ConvTranspose_21 Deconvolution jit_gemm_FP32 EXECUTED 1582
[ INFO ] ConvTranspose_22 Deconvolution jit_avx2_FP32 EXECUTED 3048
[ INFO ] ConvTranspose_26 Deconvolution jit_gemm_FP32 EXECUTED 12
[ INFO ] ConvTranspose_27 Deconvolution jit_avx2_FP32 EXECUTED 5390
[ INFO ] ConvTranspose_31 Deconvolution jit_gemm_FP32 EXECUTED 30
[ INFO ] ConvTranspose_32 Deconvolution jit_avx2_FP32 EXECUTED 7657
[ INFO ] ConvTranspose_36 Deconvolution jit_gemm_FP32 EXECUTED 102
[ INFO ] ConvTranspose_37 Deconvolution jit_avx2_FP32 EXECUTED 8292
[ INFO ] Conv_0 Convolution jit_sse42_FP32 EXECUTED 26564
[ INFO ] Conv_10 Convolution jit_avx2_FP32 EXECUTED 10198
[ INFO ] Conv_10_nChw8c_nchw_Concat_29 Reorder jit_uni_FP32 EXECUTED 105
[ INFO ] Conv_12 Convolution jit_avx2_FP32 EXECUTED 3041
[ INFO ] Conv_14 Convolution jit_avx2_FP32 EXECUTED 2726
[ INFO ] Conv_14_nChw8c_nchw_Concat_24 Reorder jit_uni_FP32 EXECUTED 21
[ INFO ] Conv_16 Convolution jit_avx2_FP32 EXECUTED 1789
[ INFO ] Conv_18 Convolution jit_avx2_FP32 EXECUTED 3186
[ INFO ] Conv_2 Convolution jit_avx2_FP32 EXECUTED 13999
[ INFO ] Conv_20 Convolution jit_avx2_FP32 EXECUTED 84
[ INFO ] Conv_20_nChw8c_nchw_ConvTranspose_21 Reorder ref_any_FP32 EXECUTED 7
[ INFO ] Conv_25 Convolution jit_avx2_FP32 EXECUTED 219
[ INFO ] Conv_25_nChw8c_nchw_ConvTranspose_26 Reorder ref_any_FP32 EXECUTED 6
[ INFO ] Conv_2_nChw8c_nchw_Concat_39 Reorder jit_uni_FP32 EXECUTED 789
[ INFO ] Conv_30 Convolution jit_avx2_FP32 EXECUTED 593
[ INFO ] Conv_30_nChw8c_nchw_ConvTranspose_31 Reorder ref_any_FP32 EXECUTED 8
[ INFO ] Conv_35 Convolution jit_avx2_FP32 EXECUTED 1175
[ INFO ] Conv_35_nChw8c_nchw_ConvTranspose_36 Reorder ref_any_FP32 EXECUTED 14
[ INFO ] Conv_4 Convolution jit_avx2_FP32 EXECUTED 14126
[ INFO ] Conv_40 Convolution jit_avx2_FP32 EXECUTED 2298
[ INFO ] Conv_40_nChw8c_nchw_out_Conv_40 Reorder ref_any_FP32 EXECUTED 30
[ INFO ] Conv_6 Convolution jit_avx2_FP32 EXECUTED 10050
[ INFO ] Conv_6_nChw8c_nchw_Concat_34 Reorder jit_uni_FP32 EXECUTED 321
[ INFO ] Conv_8 Convolution jit_avx2_FP32 EXECUTED 5448
[ INFO ] LeakyRelu_111863 ReLU undef NOT_RUN 0
[ INFO ] LeakyRelu_11867 ReLU undef NOT_RUN 0
[ INFO ] LeakyRelu_131871 ReLU undef NOT_RUN 0
[ INFO ] LeakyRelu_151847 ReLU undef NOT_RUN 0
[ INFO ] LeakyRelu_171883 ReLU undef NOT_RUN 0
[ INFO ] LeakyRelu_191887 ReLU undef NOT_RUN 0
[ INFO ] LeakyRelu_231851 ReLU jit_avx2_FP32 EXECUTED 15
[ INFO ] LeakyRelu_231851_nChw8c_nchw_Concat_24 Reorder jit_uni_FP32 EXECUTED 19
[ INFO ] LeakyRelu_281855 ReLU jit_avx2_FP32 EXECUTED 29
[ INFO ] LeakyRelu_281855_nChw8c_nchw_Concat_29 Reorder jit_uni_FP32 EXECUTED 36
[ INFO ] LeakyRelu_31839 ReLU undef NOT_RUN 0
[ INFO ] LeakyRelu_331859 ReLU jit_avx2_FP32 EXECUTED 41
[ INFO ] LeakyRelu_331859_nChw8c_nchw_Concat_34 Reorder jit_uni_FP32 EXECUTED 89
[ INFO ] LeakyRelu_381879 ReLU jit_avx2_FP32 EXECUTED 173
[ INFO ] LeakyRelu_381879_nChw8c_nchw_Concat_39 Reorder jit_uni_FP32 EXECUTED 342
[ INFO ] LeakyRelu_51875 ReLU undef NOT_RUN 0
[ INFO ] LeakyRelu_71843 ReLU undef NOT_RUN 0
[ INFO ] LeakyRelu_91891 ReLU undef NOT_RUN 0
[ INFO ] input.1_nchw_nChw8c_Conv_0 Reorder ref_any_FP32 EXECUTED 1276
[ INFO ] out_Conv_40 Output unknown_FP32 NOT_RUN 0
(1, 2, 96, 128)
saving to.. results/core/imageflow.png
Create progress tracker
CPU
# End of output for job 70401.v-qsvr-2.devcloud-edge
# Date: Thu Feb 18 05:59:17 PST 2021
sys.argv[2]=[70401.v-qsvr-2.devcloud-edge]
sys.argv[3]=[45]
sys.argv[4]=[1613656712]
sys.argv[5]=[1613656757]
USER_ID=[u60570]
JOB_ID=[70401]
JOB_RUNTIME=[45]
FROM_TIME=[1613656712]
TO_TIME=[1613656757]
INTEL_SKU=[core-i5]
Munesh_Intel
Hi Yenfu,
Since you have posted the same question in Intel® DevCloud for Edge forum, I will proceed to close this thread.
Please continue further communication at the following thread:
https://community.intel.com/t5/Intel-DevCloud-for-Edge/Problem-on-Hetero-FPGA-CPU-Implementation-on-FlowNetS-model/m-p/1257201
Munesh
