OpenVINO 2020.4 monitors
WU__Tianwen
2020.4 YOLO demo uses OpenVINO monitors,but how could i use it
monitors.py
try:
    from monitors_extension import Presenter
except ImportError:
    import logging
    class Presenter:
        def __init__(self, keys, yPos=20, graphSize=(150, 60), historySize=20):
            self.yPos = yPos
            self.graphSize = graphSize
            self.graphPadding = 0
            if keys:
                logging.warning("monitors_extension wasn't found")
        def handleKey(self, key): pass
        def drawGraphs(self, frame): pass
        def reportMeans(self): return ''
 these functions are all empty?
args.add_argument('-u', '--utilization_monitors', default='', type=str,
help='Optional. List of monitors to show initially.')
 whatever the input,the output always "monitors_extension wasn't found" ?
How could i use monitors correctly or it's not finished yet?
Max_L_Intel
Hi @WU__Tianwen
Utilization monitors feature thru -u parameter is not yet implemented for Object Detection YOLO Python Demo. Be default there is empty value "" provided, and in case of non-empty value provided it just throws the exception message via monitors.py.
You can take a look at the example on how this is implemented in Classification C++ Demo.
With "-u CMD" you can have all 3 utilization monitors being enabled for CPU, all the cores, and memory.
C:\Users\user\Documents\Intel\OpenVINO\omz_demos_build\intel64\Release>classification_demo.exe -m C:\Users\user\Documents\Intel\OpenVINOn\openvino_models\ir\public\squeezenet1.1\FP16\squeezenet1.1.xml -i "C:\Program Files (x86)\IntelSWTools\openvino_2020.4.287\deployment_tools\demo\car.png" -labels "C:\Program Files (x86)\IntelSWTools\openvino_2020.4.287\deployment_tools\open_model_zoo\demos\classification_demo\synset_words.txt" -u CMD
[ INFO ] Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ]     C:\Program Files (x86)\IntelSWTools\openvino_2020.4.287\deployment_tools\demo\car.png
FPS: 182.257
Latency: 0.0139791
Mean core utilization: 67.7% 42.1% 41.4% 44.9% 52.0% 47.4% 44.9% 53.3%
Mean CPU utilization: 49.2%
Memory mean usage: 3.4 GiB
Mean swap usage: 0.1 GiB
Iffa_Intel
Greetings,
1.May I know whether this script is from our official OpenVino documentation?
2.Is this where you are referring to?: https://github.com/TNTWEN/OpenVINO-YOLOV4
3.I checked the whole openvino folders but I could only found monitors.cpp instead of monitors.py, probably you could try out this monitors.cpp.
Sincerely,
Iffa
WU__Tianwen
Hello!
Openvino2020R4 yolov3 python demo use monitors.
https://github.com/TNTWEN/OpenVINO-YOLOV4  this is my project ,and in this issue https://github.com/TNTWEN/OpenVINO-YOLOV4/issues/1 we talked about monitors.
for windows OpenVINO (install in the default path) , python monitor files  path:
C:\Program Files (x86)\IntelSWTools\openvino_2020.4.287\deployment_tools\inference_engine\demos\python_demos\common
Add these files to the project and demo will not report errors
but this .py file  doesn't seem to implement any function
 Copyright (C) 2020 Intel Corporation
 Licensed under the Apache License, Version 2.0 (the "License");
 you may not use this file except in compliance with the License.
 You may obtain a copy of the License at
      http://www.apache.org/licenses/LICENSE-2.0
 Unless required by applicable law or agreed to in writing, software
 distributed under the License is distributed on an "AS IS" BASIS,
 WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 See the License for the specific language governing permissions and
 limitations under the License.
try:
except ImportError:
    import logging
    class Presenter:
            self.yPos = yPos
            if keys:
 I also found cpp monitors files,
C:\Program Files (x86)\IntelSWTools\openvino_2020.4.287\deployment_tools\open_model_zoo\demos\common\monitors
But it seems that it can't be used directly in Python demo
Thanks!
Max_L_Intel
Hi @WU__Tianwen
FPS: 182.257
Latency: 0.0139791
