OpenVINO CPU Scaling Bottleneck
nurac
Hey all,
I've opened a CPU scaling performance issue with OpenVINO and the details are on GitHub:
https://github.com/openvinotoolkit/openvino/issues/35133
Has anyone encountered similar issues before and solved it? Please advice.
Wan_Intel
Hi nurac,
I noticed that you are using an older version of OpenVINO™ docker image. You may install the latest version and see if the issue persists.
Please refer to the following link for more information:
https://hub.docker.com/r/openvino/ubuntu24_dev
Wan
nurac
Hi Wan,
Thanks for the reply. Apparently the issue is reproducible with the latest version. The results hasn't changed across versions. The CPU scaling ceiling is identical in OV 2026.0.0 as well.
Arun
Wan_Intel
Hi nurac,
Thank you for the information.
We will continue our conversation at https://github.com/openvinotoolkit/openvino/issues/35133 and we will proceed with closing current thread.
Wan
