6605 Discussions
[OpenVINO CPU support] Does OpenVino support Xeon D processor?
DHQNAP
Hi
As title, I'd like to confirm if Openvino support below processor?
1-Intel Xeon D-2166NT
2-Intel Xeon D-2146NT
3-Intel Xeon D-2123IT
Could you kindly help to confirm as above? Thanks.
Munesh_Intel
Hi Daniel Hsieh,
Xeon D processors have not been validated for OpenVINO. However, you can try and validate on your side, and share the results here for the benefit of our OpenVINO Community.
Munesh
DHQNAP
Thanks, Munesh.
Since I'm new to Openvino, is any quick command or step to validate the Xeon D with openvino toolkit?
Munesh_Intel
Hi Daniel Hsieh,
Xeon D is not officially supported for OpenVINO, and here is the link for you to run the verification demo scripts. Give it a shot and go through the steps one by one to see if it works.
The OpenVINO installation guides are available here:
https://docs.openvinotoolkit.org/2021.2/installation_guides.html
For Windows:
Installation:
https://docs.openvinotoolkit.org/2021.2/openvino_docs_install_guides_installing_openvino_windows.html
Demo Scripts:
https://docs.openvinotoolkit.org/latest/openvino_docs_get_started_get_started_windows.html#use_the_demo_scripts_to_learn_the_workflow
For Linux:
Installation:
https://docs.openvinotoolkit.org/2021.2/openvino_docs_install_guides_installing_openvino_linux.html
Demo Scripts:
https://docs.openvinotoolkit.org/2021.2/openvino_docs_get_started_get_started_linux.html#use_the_demo_scripts_to_learn_the_workflow
You can try running Image Classification Demo Script or Inference Pipeline Demo Script.
Munesh
Munesh_Intel
Hi Daniel,
This thread will no longer be monitored since we have provided references. If you need any additional information from Intel, please submit a new question.
Munesh
