6592 Discussions
OpenVINO Demo Compile Error (Mac OSX 10.15.6)
raymondlo84
I'm trying to compile the demo code at ...
raylo@Raymonds-MacBook-Pro ~ % cd inference_engine_demos_build
raylo@Raymonds-MacBook-Pro inference_engine_demos_build % make
So it seems the input.cpp is not compiling. Any patches I can use?
Thank you.
Scanning dependencies of target common
[ 48%] Building CXX object multi_channel/common/CMakeFiles/common.dir/decoder.cpp.o
[ 49%] Building CXX object multi_channel/common/CMakeFiles/common.dir/graph.cpp.o
[ 50%] Building CXX object multi_channel/common/CMakeFiles/common.dir/input.cpp.o
/Users/raylo/intel/openvino_2020.4.287/deployment_tools/inference_engine/demos/multi_channel/common/input.cpp:283:10: error:
      'start' overrides a member function but is not marked 'override' [-Werror,-Winconsistent-missing-override]
    void start();
/Users/raylo/intel/openvino_2020.4.287/deployment_tools/inference_engine/demos/multi_channel/common/input.cpp:39:18: note:
      overridden virtual function is here
    virtual void start() = 0;
/Users/raylo/intel/openvino_2020.4.287/deployment_tools/inference_engine/demos/multi_channel/common/input.cpp:290:10: error:
      'read' overrides a member function but is not marked 'override' [-Werror,-Winconsistent-missing-override]
    bool read(VideoFrame& frame);
/Users/raylo/intel/openvino_2020.4.287/deployment_tools/inference_engine/demos/multi_channel/common/input.cpp:41:18: note:
    virtual bool read(VideoFrame& frame) = 0;
/Users/raylo/intel/openvino_2020.4.287/deployment_tools/inference_engine/demos/multi_channel/common/input.cpp:292:11: error:
      'getAvgReadTime' overrides a member function but is not marked 'override'
    float getAvgReadTime() const {
/Users/raylo/intel/openvino_2020.4.287/deployment_tools/inference_engine/demos/multi_channel/common/input.cpp:43:19: note:
    virtual float getAvgReadTime() const = 0;
3 errors generated.
make[2]: *** [multi_channel/common/CMakeFiles/common.dir/input.cpp.o] Error 1
make[1]: *** [multi_channel/common/CMakeFiles/common.dir/all] Error 2
raymondlo84
I took out the Werror from the CMakeLists.txt in here
/opt/intel/openvino/deployment_tools/open_model_zoo/demos
I will just take on the warning for now and getting it compiled.
-ray
raymondlo84
-ray
Rizal_Intel
Hi Raymond,
It seems you have solved the issue.
Intel will no longer monitor this thread since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Rizal
