OpenVINO HDDL-R support on Ubuntu 18
Gabriel_S_Intel
Is there OpenVINO support for HDDL-R on Ubuntu 18.04.2 LTS?
We followed the Installation guide :https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux_ivad_vpu.html
However,
1. Installation steps are available only for Ubuntu 16.04 version.
2. Same version of dependencies packages are not available on Ubuntu 18.04(also on synaptics) as mentioned in the instructions. So relative available packages were used :
libboost-program-options1.58.0 ==> libboost-program-options1.62.0
libboost-thread1.58.0 ==> libboost-thread1.62.0
libboost-filesystem1.58.0 ==> libboost-filesystem1.62-dev
libjson-c2 ==> libjson-c3
3. While installing the HDDL drivers using "sudo ./setup.sh install" (as mentioned in the instruction step 5), insmod: ERROR: could not insert module myd_vsc.ko: Operation not permitted error were observed.
HemanthKum_G_Intel
Hi Gabriel,
Officially OpenVINO supports Ubuntu 16.04 and not Ubuntu 18.04
Vladimir_Dudnik
We are glad to inform you that starting from OpenVINO 2019 R3 we have added support HDDL-R on Ubuntu 18.04
