6584 Discussions
OpenVINO Model Optimizer converts the same type of layer differently
Frostjord
Hello everyone,
I've been trying to convert YOLOv8 from Ultralytics to use it on an FPGA. To do that, I first need to get the XML file. I have the model in .onnx format, however the model optimizer converts the two Div layers present in the Model into a Divide and the other into Multiply. I used Neutron to visualize the two files. Furthermore, I don't understand it well, so I thought that I would simply be a division by a constant value and multiplying by the opposite would have the same effect. I can't find my solution elsewhere, so here I am ;).
Thanks in advance for your help
Wan_Intel
Hi Frostjord,
Please share the following details with us to further investigate the issues. Thank you.
  • Hardware details
  • Version of OpenVINO™ toolkit
  • Operating System
Wan
Frostjord
Hi, thanks for your answer.
Here are the specs of my machine :
OS Name: Microsoft Windows 10 Entreprise
Version: 10.0.19045 Build 19045
OS Manufacturer: Microsoft Corporation
System Manufacturer: HP
System Model: HP ZBook 15 G5
System Type: x64-based PC
Processor: Intel(R) Core(TM) i7-8850H CPU @ 2.60GHz, 2592 Mhz, 6 Core(s), 12 Logical Processor(s)
Installed Physical Memory (RAM): 32.0 GB
GPUs: Intel(R) UHD Graphics 630 and NVIDIA Quadro P2000
I'm developing using WSL :
WSL version: 1.2.5.0
Kernel version: 5.15.90.1
WSLg version: 1.0.51
MSRDC version: 1.2.3770
Direct3D version: 1.608.2-61064218
DXCore version: 10.0.25131.1002-220531-1700.rs-onecore-base2-hyp
Windows version: 10.0.19045.2965
And here are the specs of the Linux distro:
OS: Ubuntu 20.04.6 LTS on Windows 10 x86_64
Kernel: 5.15.90.1-microsoft-standard-WSL2 Uptime: 1 min
Packages: 1220 (dpkg)
Shell: bash 5.0.17
Theme: Adwaita [GTK3]
Icons: Adwaita [GTK3]
Terminal: Relay(10)
CPU: Intel i7-8850H (12) @ 2.592GHz
GPU: a560:00:00.0 Microsoft Corporation Device 008e
Memory: 332MiB / 15899MiB
Also, I'm using openvino and openvino-dev version 2022.3.0.
Hope that helps.
Frostjord
Wan_Intel
Hi Frostjord,
Thanks for your information.
For your information, referring to Supported Devices, FPGA does not supported in openvino-dev 2022.3.0.
For more information, please refer to What Is the Latest Version of OpenVINO™ Toolkit That Supports OpenVINO™ Toolkit FPGA?
On another note, could you please share your model with us to further investigate the issue?
waix.fook.wan@intel.com
Wan
Wan_Intel
Hi Frostjord,
Thanks for your question.
Please submit a new question if additional information is needed as this thread will no longer be monitored.
Wan
