6593 Discussions
OpenVINO Python api "get_perf_counts()" does not return any results.
arakawa__yota
I'm trying calculate inference time of IR models, and I used "get_perf_counts()" to get some informations about inference time.
I wrote the code like that
infer_request_handle = exec_net.start_async(request_id=0, inputs={input_blob: resize_img})
infer_request_handle.wait()
perf_counts = infer_request_handle.get_perf_counts()
log.info("Performance counters:")
print("{:<70} {:<15} {:<15} {:<15} {:<10}".format('name', 'layer_type', 'exet_type', 'status', 'real_time, us'))
for layer, stats in perf_counts.items():
    print("{:<70} {:<15} {:<15} {:<15} {:<10}".format(layer, stats['layer_type'], stats['exec_type'],
            stats['status'], stats['real_time']))
but, I could not get result.
Next, I executed IntelSWTools\openvino_2019.1.087\deployment_tools\inference_engine\samples\python_samples\
   classification_sample_async\classification_sample_async argument --perf_counts True.
Also in this source code "get_perf_counts()" did not return a result.
Why does it not return a results?
Shubha_R_Intel
Dear arakawa, yota,
According to the documentation (see below) on Image Classification Python Sample Async you only pass in one of these -pc or --perf_counts but you don't need to put 'True'. Also don't forget, you always have to add the -l switch for Python samples which points it to the cpu_extension.dll (or *.so) if you are running on the CPU.
 https://docs.openvinotoolkit.org/latest/_inference_engine_ie_bridges_python_sample_classification_sample_async_README.html
Shubha
Muthusamy__Suresh
