OpenVINO and Detectron
Shevchuk__Mikhailo
Shubha_R_Intel
Dear Shevchuk, Mikhailo:
The document below tells you exactly how to generate IR for maskrcnn_r50_fpn_2x as described:
https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_convert_model_tf_specific_Convert_Object_Detection_API_Models.html
Please select your Mask RCNN model from one of OpenVino's validated models here:
https://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_convert_model_Convert_Model_From_TensorFlow.html
Thanks !
Shubha
Juj__Satyajith
Dear Shubha,
That specific example is for a tensorflow model, right? If I remember correctly, model optimisation does not currently support the Detectron framework.
Correct me if I am wrong.
Shubha_R_Intel
Dear folks, This OpenVino documentation definitely mentions Detectron, so it is supported. The key though is to convert a *.pkl file to a *.pb first, since Model Optimizer does not support *.pkl.  There is a script in the Detectron github repo which enables conversion:
https://github.com/facebookresearch/Detectron/blob/master/tools/convert_pkl_to_pb.py
Shubha
