OpenVINO using MyriadX in Qt
Albi_KA
My settings:
OS: Windows 10
Qt: 5.15.2
OpenVINO: 2021.3.394
IDE: QtCreator
Python: 3.7
I would like to use the OpenVINO InferenceEngine in the OpenCV DNN module.
.pro-file:
INCLUDEPATH += "C:/Program Files (x86)/Intel/openvino_2021.3.394/opencv/include"
INCLUDEPATH += "C:/Program Files (x86)/Intel/openvino_2021.3.394/inference_engine/include"
INCLUDEPATH += "C:/Program Files (x86)/Intel/openvino_2021.3.394/inference_engine/external/tbb/include"
LIBS += -L"C:/Program Files (x86)/Intel/openvino_2021.3.394/opencv/lib"
LIBS += -lopencv_core452d
LIBS += -lopencv_dnn452d
LIBS += -lopencv_highgui452d
LIBS += -lopencv_imgcodecs452d
LIBS += -lopencv_imgproc452d
LIBS += -lopencv_video452d
LIBS += -lopencv_videoio452d
LIBS += -L"C:/Program Files (x86)/Intel/openvino_2021.3.394/inference_engine/lib/intel64/Debug"
LIBS += -linference_engined
LIBS += -linference_engine_transformationsd
LIBS += -L"C:/Program Files (x86)/Intel/openvino_2021.3.394/inference_engine/external/tbb/lib"
LIBS += -ltbb
LIBS += -ltbbmalloc
myProject.cpp-file:
cv::dnn::Net() model = cv::dnn::readNetFromTensorflow("path/to/model.pb");
model.setPreferableBackend(cv::dnn::DNN_BACKEND_INFERENCE_ENGINE);
model.setPreferableTarget(cv::dnn::DNN_TARGET_MYRIAD);
Mat inputBlob = cv::dnn::blobFromImage("path/to/image");
model.setInput(inputBlob);
Mat pred = model.forward();
The code work but the runtime is similiar as I used cv::dnn::DNN_BACKEND_OPENCV with  cv::dnn::DNN_TARGET_CPU.
Using Intel Myriad Stick should accelerate the computation?
Also I got the following outputs:
[ INFO:0] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\dnn\src\tensorflow\tf_importer.cpp (781) cv::dnn::dnn4_v20210301::`anonymous-namespace'::TFImporter::populateNet DNN/TF: parsing model (N/A version info). Number of nodes = 876
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\videoio\src\videoio_registry.cpp (217) cv::`anonymous-namespace'::VideoBackendRegistry::VideoBackendRegistry VIDEOIO: Enabled backends(8, sorted by priority): FFMPEG(1000); GSTREAMER(990); INTEL_MFX(980); MSMF(970); DSHOW(960); CV_IMAGES(950); CV_MJPEG(940); UEYE(930)
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\videoio\src\backend_plugin.cpp (335) cv::impl::getPluginCandidates Found 3 plugin(s) for FFMPEG
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\utils\plugin_loader.impl.hpp (67) cv::plugin::impl::DynamicLib::libraryLoad load C:\Optimum\projects\build-_myProject_all-Desktop_Qt_5_15_2_MSVC2019_64bit-Debug\bin\opencv_videoio_ffmpeg452_64d.dll => FAILED
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\utils\plugin_loader.impl.hpp (67) cv::plugin::impl::DynamicLib::libraryLoad load opencv_videoio_ffmpeg452_64d.dll => FAILED
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\utils\plugin_loader.impl.hpp (67) cv::plugin::impl::DynamicLib::libraryLoad load opencv_videoio_ffmpeg452_64.dll => FAILED
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\videoio\src\backend_plugin.cpp (335) cv::impl::getPluginCandidates Found 2 plugin(s) for GSTREAMER
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\utils\plugin_loader.impl.hpp (67) cv::plugin::impl::DynamicLib::libraryLoad load C:\Optimum\projects\build-_myProject_all-Desktop_Qt_5_15_2_MSVC2019_64bit-Debug\bin\opencv_videoio_gstreamer452_64d.dll => FAILED
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\utils\plugin_loader.impl.hpp (67) cv::plugin::impl::DynamicLib::libraryLoad load opencv_videoio_gstreamer452_64d.dll => FAILED
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\videoio\src\backend_plugin.cpp (335) cv::impl::getPluginCandidates Found 2 plugin(s) for INTEL_MFX
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\utils\plugin_loader.impl.hpp (67) cv::plugin::impl::DynamicLib::libraryLoad load C:\Optimum\projects\build-_myProject_all-Desktop_Qt_5_15_2_MSVC2019_64bit-Debug\bin\opencv_videoio_intel_mfx452_64d.dll => FAILED
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\utils\plugin_loader.impl.hpp (67) cv::plugin::impl::DynamicLib::libraryLoad load opencv_videoio_intel_mfx452_64d.dll => FAILED
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\videoio\src\backend_plugin.cpp (335) cv::impl::getPluginCandidates Found 2 plugin(s) for MSMF
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\utils\plugin_loader.impl.hpp (67) cv::plugin::impl::DynamicLib::libraryLoad load C:\Optimum\projects\build-_myProject_all-Desktop_Qt_5_15_2_MSVC2019_64bit-Debug\bin\opencv_videoio_msmf452_64d.dll => OK
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\videoio\src\backend_plugin.cpp (50) cv::impl::PluginBackend::initCaptureAPI Found entry: 'opencv_videoio_capture_plugin_init_v1'
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\videoio\src\backend_plugin.cpp (169) cv::impl::PluginBackend::checkCompatibility Video I/O: initialized 'Microsoft Media Foundation OpenCV Video I/O plugin': built with OpenCV 4.5 (ABI/API = 1/1), current OpenCV version is '4.5.2-openvino' (ABI/API = 1/1)
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\20Tot. Runtime: 8719.01
21.3\build\windows\opencv\modules\videoio\src\backend_plugin.cpp (69) cv::impl::PluginBackend::initCaptureAPI Video I/O: plugin is ready to use 'Microsoft Media Foundation OpenCV Video I/O plugin'
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\videoio\src\backend_plugin.cpp (84) cv::impl::PluginBackend::initWriterAPI Found entry: 'opencv_videoio_writer_plugin_init_v1'
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\videoio\src\backend_plugin.cpp (103) cv::impl::PluginBackend::initWriterAPI Video I/O: plugin is ready to use 'Microsoft Media Foundation OpenCV Video I/O plugin'
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\videoio\src\cap_msmf.cpp (787) CvCapture_MSMF::configureHW MSMF: Using D3D11 video acceleration on GPU device: NVIDIA TITAN RTX
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\parallel\registry_parallel.impl.hpp (90) cv::parallel::ParallelBackendRegistry::ParallelBackendRegistry core(parallel): Enabled backends(3, sorted by priority): ONETBB(1000); TBB(990); OPENMP(980)
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\utils\plugin_loader.impl.hpp (67) cv::plugin::impl::DynamicLib::libraryLoad load C:\Optimum\projects\build-_myProject_all-Desktop_Qt_5_15_2_MSVC2019_64bit-Debug\bin\opencv_core_parallel_onetbb452_64d.dll => FAILED
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\utils\plugin_loader.impl.hpp (67) cv::plugin::impl::DynamicLib::libraryLoad load opencv_core_parallel_onetbb452_64d.dll => FAILED
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\utils\plugin_loader.impl.hpp (67) cv::plugin::impl::DynamicLib::libraryLoad load C:\Optimum\projects\build-_myProject_all-Desktop_Qt_5_15_2_MSVC2019_64bit-Debug\bin\opencv_core_parallel_tbb452_64d.dll => OK
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\parallel\plugin_parallel_wrapper.impl.hpp (48) cv::impl::PluginParallelBackend::initPluginAPI core(parallel): plugin is ready to use 'TBB (interface 9107) OpenCV parallel plugin'
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\include\opencv2/core/parallel/backend/parallel_for.tbb.hpp (54) cv::parallel::tbb::ParallelForBackend::ParallelForBackend Initializing TBB parallel backend: TBB_INTERFACE_VERSION=9107
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\parallel\parallel.cpp (73) cv::parallel::createParallelForAPI core(parallel): using backend: TBB (priority=990)
[ INFO:8] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\utils\plugin_loader.impl.hpp (74) cv::plugin::impl::DynamicLib::libraryRelease unload C:\Optimum\projects\build-_myProject_all-Desktop_Qt_5_15_2_MSVC2019_64bit-Debug\bin\opencv_videoio_msmf452_64d.dll
[ INFO:8] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\utils\plugin_loader.impl.hpp (74) cv::plugin::impl::DynamicLib::libraryRelease unload C:\Optimum\projects\build-_myProject_all-Desktop_Qt_5_15_2_MSVC2019_64bit-Debug\bin\opencv_core_parallel_tbb452_64d.dll
[E:] [BSL] found 0 ioexpander device
What does this error mean? What is missing in my code/libraries? How could I accelerate my computations with Intel MyriadX?
Zulkifli_Intel
Hello Bianca Lamm
Greetings to you.
Intel Movidius Myriad X is the accelerator for DNN interference. For the [E:] [BSL] found 0 ioexpander device message, we’re still investigating the cause. We’ll get back to you soon.
Zulkifli_Intel
Hello Bianca Lamm.
For the [E:] [BSL] found 0 ioexpander device message, it seems like it is not an error. You can refer to GitHub thread where the user encountered the same message.
Sincerely,
Zulkifli
Zulkifli_Intel
Hello Bianca Lamm,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Zulkifli
