OpenVINO with OnnxRuntime in Intel i5-8500
AidenZhang
Hello
I try to use openVINO in this CPU Intel i5- 8500  UHD 630 .to deploy the AI model.
I am now using the Microsoft.ML.OnnxRuntime.OpenVino.1.20.0 nupkg .
But it can start the program , when i use the EP with OnnxRuntime. it can not start the program , when I use this code
try
std::vector<std::string> labels = { "test" };// readClassNames();
std::string onnxpath = "best.onnx";
sessionOptions.SetIntraOpNumThreads(10);
OrtSessionOptionsAppendExecutionProvider_OpenVINO(
sessionOptions,
"GPU"
std::wstring modelPathBy = std::wstring(onnxpath.begin(), onnxpath.end());
Ort::Session session(env, modelPathBy.c_str(), sessionOptions);
Labels (2)
Zulkifli_Intel
Hi AidenZhang,
Thank you for reaching out.
May I know which model you are using. If possible can you share the steps to reproduce the issue?
Zul
AidenZhang
Hello Zulkfli,
I am now using the YoloV8 model , export to Onnx model ,the version is 1.16.2 in python environment.
the C++ project ,I use the Microsoft.ML.OnnxRuntime.OpenVINO 1.20.0  .
it cannot run the C++ program in the I5-8500 CPU laptop.
Zulkifli_Intel
Hi AidenZhang
Based on Requirements, ONNX Runtime OpenVINO™ Execution Provider is compatible with three latest releases of OpenVINO™:
ONNX Runtime
OpenVINO™
Notes
1.19.0
2024.3
Details
1.18.0
2024.1
Details
1.17.1
2023.3
Details
It seems like you are not using the supported version.
Zul
Zulkifli_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
