6605 Discussions
OpennVino and Intel Realsense collaboration work Ubuntu 18.04.
Alexiif
can't compile Intel Realsense with oppenvino support. All version contain some errors.
I got this errors  on openvino 2019.3.334 and realsense 2.37.
[ 50%] Building CXX object wrappers/openvino/face/CMakeFiles/rs-face-vino.dir/rs-face-vino.cpp.o
In file included from /opt/intel/openvino/inference_engine/include/ie_plugin_ptr.hpp:11:0,
                 from /opt/intel/openvino/inference_engine/include/ie_plugin_dispatcher.hpp:11,
                 from /opt/intel/openvino/inference_engine/include/inference_engine.hpp:21,
                 from /home/navigator/IntelEdge/librealsense-2.37.0/wrappers/openvino/./rs-vino/openvino-helpers.h:15,
                 from /home/navigator/IntelEdge/librealsense-2.37.0/wrappers/openvino/./rs-vino/base-detection.h:7,
                 from /home/navigator/IntelEdge/librealsense-2.37.0/wrappers/openvino/./rs-vino/object-detection.h:6,
                 from /home/navigator/IntelEdge/librealsense-2.37.0/wrappers/openvino/face/rs-face-vino.cpp:8:
/opt/intel/openvino/inference_engine/include/details/ie_so_pointer.hpp: In instantiation of ‘InferenceEngine::details::SOPointer<T, Loader>::SOPointer(const file_name_t&) [with T = InferenceEngine::IExtension; Loader = InferenceEngine::details::SharedObjectLoader; file_name_t = std::__cxx11::basic_string<wchar_t>]’:
/opt/intel/openvino/inference_engine/include/ie_extension.h:56:26:   required from here
/opt/intel/openvino/inference_engine/include/details/ie_so_pointer.hpp:90:22: error: no matching function for call to ‘InferenceEngine::details::SharedObjectLoader::SharedObjectLoader(const wchar_t*)’
         : _so_loader(new Loader(name.c_str()))
In file included from /opt/intel/openvino/inference_engine/include/details/ie_so_loader.h:12:0,
                 from /opt/intel/openvino/inference_engine/include/details/ie_so_pointer.hpp:12,
                 from /opt/intel/openvino/inference_engine/include/ie_plugin_ptr.hpp:11,
/opt/intel/openvino/inference_engine/include/details/os/lin_shared_object_loader.h:32:14: note: candidate: InferenceEngine::details::SharedObjectLoader::SharedObjectLoader(const char*)
     explicit SharedObjectLoader(const char* pluginName) {
/opt/intel/openvino/inference_engine/include/details/os/lin_shared_object_loader.h:32:14: note:   no known conversion for argument 1 from ‘const wchar_t*’ to ‘const char*’
/opt/intel/openvino/inference_engine/include/details/os/lin_shared_object_loader.h:22:7: note: candidate: constexpr InferenceEngine::details::SharedObjectLoader::SharedObjectLoader(const InferenceEngine::details::SharedObjectLoader&)
 class SharedObjectLoader {
/opt/intel/openvino/inference_engine/include/details/os/lin_shared_object_loader.h:22:7: note:   no known conversion for argument 1 from ‘const wchar_t*’ to ‘const InferenceEngine::details::SharedObjectLoader&’
/opt/intel/openvino/inference_engine/include/details/ie_so_pointer.hpp: In instantiation of ‘InferenceEngine::details::SOPointer<T, Loader>::SOPointer(const file_name_t&) [with T = InferenceEngine::IShapeInferExtension; Loader = InferenceEngine::details::SharedObjectLoader; file_name_t = std::__cxx11::basic_string<wchar_t>]’:
/opt/intel/openvino/inference_engine/include/ie_extension.h:130:26:   required from here
wrappers/openvino/face/CMakeFiles/rs-face-vino.dir/build.make:62: recipe for target 'wrappers/openvino/face/CMakeFiles/rs-face-vino.dir/rs-face-vino.cpp.o' failed
make[2]: *** [wrappers/openvino/face/CMakeFiles/rs-face-vino.dir/rs-face-vino.cpp.o] Error 1
CMakeFiles/Makefile2:305: recipe for target 'wrappers/openvino/face/CMakeFiles/rs-face-vino.dir/all' failed
make[1]: *** [wrappers/openvino/face/CMakeFiles/rs-face-vino.dir/all] Error 2
Makefile:129: recipe for target 'all' failed
make: *** [all] Error 2
I got errors on versions openvino 2021.4 and librealsense-2.45, and any other combinations. I want to know that combinations of versions of openvino and librealsense compile without errors on Ubuntu 18.04.
okih
Hi, just FYI
It seems librealsense-2.4x openvino support still uses IE APIs removed in 2021.x.
You can find a pull request to support 2021.x at https://github.com/IntelRealSense/librealsense/pull/9273 .
librealsense-2.45.0 can be compiled with openvino 2020.3.2 LTS on utuntu 18.04 and gcc 7.5.0 to modify the followings in
librealsense-2.45.0/tools/realsense-viewer/openvino-face-detection.cpp :
40c40
< void detected_face::update_age( float value )
> void update_age( float value )
45c45
< void detected_face::update_gender( float value )
> void update_gender( float value )
207c207
< rs2::depth_frame df = NULL;
> rs2::depth_frame df = rs2::frame{};
These can avoid the errors.
/home/hood/build/librealsense/librealsense-2.45.0/tools/realsense-viewer/openvino-face-detection.cpp:40:10: error: extra qualification ‘detected_face::’ on member ‘update_age’ [-fpermissive]
/home/hood/build/librealsense/librealsense-2.45.0/tools/realsense-viewer/openvino-face-detection.cpp:45:10: error: extra qualification ‘detected_face::’ on member ‘update_gender’ [-fpermissive]
/home/hood/build/librealsense/librealsense-2.45.0/tools/realsense-viewer/openvino-face-detection.cpp: In member function ‘virtual void openvino_face_detection::worker_body(rs2::frame)’:
/home/hood/build/librealsense/librealsense-2.45.0/tools/realsense-viewer/openvino-face-detection.cpp:207:31: error: conversion from ‘long int’ to non-scalar type ‘rs2::depth_frame’ requested
Syamimi_Intel
Hi Alex Popov,
Thank you for reaching out. Did your issue solve with the answer given by Okih?
Hi Okih,
Thank you for sharing the answer.
Syamimi
Syamimi_Intel
Hi Alex Popov,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Syamimi
