Openvino error
Dharmisha_D_Intel
ERROR: CL_DEVICE_NOT_FOUND
I get this error when trying to run openvino with FPGA in containers. what am i missing.
Shubha_R_Intel
Dear Dharmisha D.,
Perhaps this demo will help you :
https://github.com/intel/intel-device-plugins-for-kubernetes/tree/master/demo#intel-fpga-device-plugin-demo-video
Let me know -
Shubha
Dharmisha_D_Intel
This is the demo that I am following. It works fine with the nlb3 demo bitsteam, but not for openvino related inference workloads.
Shubha_R_Intel
Dear Dharmisha D.
Do any other OpenCL workloads work on the board?  I’d make sure the board is functioning properly first. In other words, remove the containers from the equation first.
Hope it helps,
Shubha
Dharmisha_D_Intel
When I run on Bare metal it works fine
In Containers. I get the following error with opencl workloads
root@caas-openvino-object-detection:/# /opt/intel/openvino/inference_engine/samples/build/intel64/Release/object_detection_demo -i /opt/intel/openvino/deployment_tools/demo/car.png -m /VGG16_faster_rcnn_final.xml -d HETERO:FPGA,CPU
[ INFO ] InferenceEngine:
        API version ............ 1.6
        Build .................. custom_releases/2019/R1.1_28dfbfdd28954c4dfd2f94403dd8dfc1f411038b
Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ]     /opt/intel/openvino/deployment_tools/demo/car.png
[ INFO ] Loading plugin
        Build .................. heteroPlugin
        Description ....... heteroPlugin
[ INFO ] Loading network files:
        /VGG16_faster_rcnn_final.bin
[ INFO ] num_classes guessed: 21
[ INFO ] Preparing input blobs
[ INFO ] Batch size is 1
[ INFO ] Preparing output blobs
[ INFO ] Loading model to the plugin
Error initializing DMA: 1
Error initializing mmd dma
Error initializing bsp
terminate called after throwing an instance of 'dla::error'
Aborted (core dumped)
FPGA is accessible to the container. It also has access to /dev/intel-fpga-port.0.
root@non-faas-openvino-object-detection:/# fpgainfo fme
Board Management Controller, microcontroller FW version 26889
Last Power Down Cause: POK_CORE
Last Reset Cause: None
//****** FME ******//
Object Id                     : 0xED00000
PCIe s:b:d:f                  : 0000:AF:00:0
Device Id                     : 0x09C4
Socket Id                     : 0x00
Ports Num                     : 01
Bitstream Id                  : 0x123000200000185
Bitstream Version             : 0x746E692F00030201
Pr Interface Id               : 69528db6-eb31-577a-8c36-68f9faa081f6
root@non-faas-openvino-object-detection:/# lsmod | grep fpga
intel_fpga_pac_hssi    18347  0
intel_fpga_fme         54120  0
intel_fpga_afu         32069  0
fpga_mgr_mod           14693  1 intel_fpga_fme
intel_fpga_pci         26684  2 intel_fpga_afu,intel_fpga_fme
I was trying to debug using the simple aocl list-devices on bare metal and in container command and got the following error:
  1. Bare-metal
  1. Container: It says the card is uninitialized , however it is already programmed and initialized.
Shubha_R_Intel
Dear Dharmisha D,
It looks to me that you are on a very old OpenVino version... API version ............ 1.6.
We just released OpenVino 2019R3. Can you kindly try again with the latest release ?
Shubha
