Openvino memory access exception
praedos
I've installed Openvino on my Pycharm using the terminal like it's described at https://www.intel.com/content/www/us/en/developer/tools/openvino-toolkit/download.html?PACKAGE=OPENVINO_BASE&VERSION=v_2025_0_0&OP_SYSTEM=WINDOWS&DISTRIBUTION=PIP and I have update the driver version of my Graphic card Intel UHD Graphics 630.
To verify that the package is installed I've run this code:
from openvino import Core
print(f"Devices: {Core().get_available_devices()}")
But I have the following message:
Process finished with exit code -1073741819 (0xC0000005)
That means: Access Violation.
Could it be that the programme tried to access to a memory location that it did not have permission to access? How can I fix it?
Thank you
Wan_Intel
Hi praedos,
May I know which Python version are you using on your system? Did you create a virtual environment when installing OpenVINO™? If yes, could you please remove existing virtual environment, and re-install OpenVINO™ with a new virtual environment?
Wan
praedos
I'm sorry, I forgot to mention the Python version and OS. I'm using the Python 3.13 and Windows 10. I've created a new enviroment and I have installed openvino 2025.0.0 I've tried to launch this code:
core = Core()
available_devices = core.available_devices
print(f"Available Devices: {available_devices}")
But it fails at:
core = Core()
with the error:
Best regards
Wan_Intel
Hi praedos,
Thank you for providing the information.
For your information, could you please downgrade your Python version to Python 3.9 - 3.12 because Python 3.13 is not supported yet.
After you uninstall Python 3.13 and installed Python 3.9 - 3.12, you may re-install OpenVINO™ 2025 again.
Wan
Wan_Intel
Hi praedos,
Thank you for your question.
We will proceed with closing this thread. If you need additional information from Intel, please submit a new question as this thread will no longer be monitored.
Wan
