6594 Discussions
Openvino2023.0 will report error if using dynamic shape
huany11
(openvino_env) PS T:\openvino\openvino_env\Scripts> .\benchmark_app.exe -m T:\openvino\models\angio_segmentation_48.onnx -shape [345,48,48,1] -d GPU -niter 8
[Step 1/11] Parsing and validating input arguments
[ INFO ] Parsing input parameters
[Step 2/11] Loading OpenVINO Runtime
[ INFO ] OpenVINO:
[ INFO ] Build ................................. 2023.0.1-11005-fa1c41994f3-releases/2023/0
[ INFO ]
[ INFO ] Device info:
[ INFO ] GPU
[ INFO ]
[ INFO ]
[Step 3/11] Setting device configuration
[ WARNING ] Performance hint was not explicitly specified in command line. Device(GPU) performance hint will be set to PerformanceMode.THROUGHPUT.
[Step 4/11] Reading model files
[ INFO ] Loading model files
[ INFO ] Read model took 60.83 ms
[ INFO ] Original model I/O parameters:
[ INFO ] Model inputs:
[ INFO ] x (node: x) : f32 / [...] / [?,48,48,1]
[ INFO ] Model outputs:
[ INFO ] activation_40 (node: activation_40) : f32 / [...] / [?,2304,2]
[Step 5/11] Resizing model to match image sizes and given batch
[ INFO ] Model batch size: 345
[ INFO ] Reshaping model: 'x': [345,48,48,1]
[ INFO ] Reshape model took 29.90 ms
[Step 6/11] Configuring input of the model
[ INFO ] x (node: x) : f32 / [N,H,W,C] / [345,48,48,1]
[ INFO ] activation_40 (node: activation_40) : f32 / [...] / [345,2304,2]
[Step 7/11] Loading the model to the device
[ ERROR ] Check 'false' failed at C:\Jenkins\workspace\private-ci\ie\build-windows-vs2019@3\b\repos\openvino\src\inference\src\core.cpp:117:
Check 'std::numeric_limits<StorageDataType>::max() >= value' failed at C:\Jenkins\workspace\private-ci\ie\build-windows-vs2019@3\b\repos\openvino\src\core\include\openvino/op/constant.hpp:521
Traceback (most recent call last):
File "T:\openvino\openvino_env\lib\site-packages\openvino\tools\benchmark\main.py", line 408, in main
compiled_model = benchmark.core.compile_model(model, benchmark.device, device_config)
File "T:\openvino\openvino_env\lib\site-packages\openvino\runtime\ie_api.py", line 398, in compile_model
super().compile_model(model, device_name, {} if config is None else config),
RuntimeError: Check 'false' failed at C:\Jenkins\workspace\private-ci\ie\build-windows-vs2019@3\b\repos\openvino\src\inference\src\core.cpp:117:
Wan_Intel
Hello Huany11,
Is your model Natural Language Processing model? Dynamic shapes are now supported for GPU inference for Natural Language Processing models. More models will be supported in future OpenVINO releases. You may refer to the link below for more information:
https://www.intel.com/content/www/us/en/developer/articles/release-notes/openvino/2023-0.html
Please share your model with us if it is Natural Language Processing model.
Wan
Wan_Intel
Hello Huany11,
If you need any additional information from Intel, please submit a new question as this thread will no longer be monitored.
Wan
