6597 Discussions
Person Tracking OpenVINO Python example syntax error
jvkloc
 I'm trying to run the Python person tracking example from the OpenVINO website and I get a syntax error from
! $download_command
If I put the whole line into quotes, there is no error. But then the script doesn't download the model files. How can I download the files for the example? The whole code until the error:
import collections
import sys
import time
import numpy as np
import cv2
#from IPython import display
import matplotlib.pyplot as plt
from openvino.runtime import Core
from Model import Model
#sys.path.append("../utils")
#import notebook_utils as utils
from deep_sort.deep_sort.tracker import Tracker
from deep_sort.deep_sort.nn_matching import NearestNeighborDistanceMetric
from deep_sort.deep_sort.detection import Detection
# A directory where the model will be downloaded.
base_model_dir = "Downloads"
precision = "FP16"
# The name of the model from Open Model Zoo
detection_model_name = "person-detection-0203"
download_command = f"omz_downloader " \
                   f"--name {detection_model_name} " \
                   f"--precisions {precision} " \
                   f"--output_dir {base_model_dir} " \
                   f"--cache_dir {base_model_dir}"
! $download_command
detection_model_path = f"Downloads/intel/{detection_model_name}/{precision}/{detection_model_name}.xml"
reidentification_model_name = "person-reidentification-retail-0277"
                   f"--name {reidentification_model_name} " \
! $download_command
reidentification_model_path = f"Downloads/intel/{reidentification_model_name}/{precision}/{reidentification_model_name}.xml"
detector = Model(detection_model_path)
# since the number of detection object is uncertain, the input batch size of reid model should be dynamic
extractor = Model(reidentification_model_path, -1)
Hairul_Intel
Hi jvkloc,
For your information, the Python example is from our OpenVINO Notebook tutorials. Please install Jupyter Notebook following this installation guide to run the tutorial.
Next, run the following command to start the 407-person-tracking-webcam notebook:
jupyter lab notebooks\407-person-tracking-webcam\407-person-tracking.ipynb
Hope this helps.
Hairul
jvkloc
Hello!
Thank you for your reply. My aim is to use person tracking as part of another program and Notebook is not an option. How can I download the model files for OpenVINO? I'm using Python 3.9 and Ubuntu 22.04.
Hairul_Intel
Hi jvkloc,
The models used for the example are person-detection-0202 and person-reidentification-retail-0287 which are mentioned in Download the Model section.
Install OpenVINO Development Tools and run the following command in a terminal to download the respective models:
omz_downloader --name person-detection-0202
omz_downloader --name person-reidentification-retail-0287
Hairul
jvkloc
Great, thank you! I got the downloads to right folders but now line 42 of my code (in the first post)
gives
builtins.RuntimeError: Check 'false' failed at C:\Jenkins\workspace\private-ci\ie\build-windows-vs2019\b\repos\openvino\src\inference\src\core.cpp:100:
Model file Downloads/intel/person-detection-0203/FP16/person-detection-0203.xml cannot be opened!
 This is the example code of Model class up to the line 17 which causes the error above.
ie_core = Core()
class Model:
    This class represents a OpenVINO model object.
    def __init__(self, model_path, batchsize=1, device="AUTO"):
        Initialize the model object
        Parameters
        model_path: path of inference model
        batchsize: batch size of input data
        device: device used to run inference
        self.model = ie_core.read_model(model=model_path)
 How can this be fixed?
EDIT: I have checked the files and folders, they're in the right place.
Hairul_Intel
Hi jvkloc,
Please provide the full script of your example to us so that we can investigate this issue further.
Furthermore, please share the list of your installed pip modules with us. Run the following command to print the list of installed modules:
pip list
Hairul
jvkloc
here is the pip list:
Package             Version
addict              2.4.0
asttokens           2.2.1
backcall            0.2.0
beautifulsoup4      4.12.2
certifi             2023.5.7
charset-normalizer  3.1.0
colorama            0.4.6
comm                0.1.3
contourpy           1.1.0
cycler              0.11.0
dearpygui           1.9.1
debugpy             1.6.7
decorator           5.1.1
defusedxml          0.7.1
executing           1.2.0
filelock            3.12.2
filterpy            1.4.5
fonttools           4.40.0
gdown               4.7.1
gitdb               4.0.10
GitPython           3.1.31
idna                3.4
importlib-metadata  6.7.0
importlib-resources 5.12.0
ipyfilechooser      0.6.0
ipykernel           6.23.3
ipython             8.14.0
ipywidgets          8.0.6
jedi                0.18.2
Jinja2              3.1.2
jstyleson           0.0.2
jupyter_client      8.3.0
jupyter_core        5.3.1
jupyterlab-widgets  3.0.7
kiwisolver          1.4.4
loguru              0.7.0
MarkupSafe          2.1.3
matplotlib          3.7.1
matplotlib-inline   0.1.6
motmetrics          1.4.0
motrackers          0.0.1
mpmath              1.3.0
nest-asyncio        1.5.6
networkx            2.8.8
numpy               1.23.1
opencv-python       4.8.0.74
openvino            2023.0.0
openvino-dev        2023.0.0
openvino-telemetry  2023.0.0
osc4py3             1.0.8
packaging           23.1
pandas              2.0.3
parso               0.8.3
pickleshare         0.7.5
Pillow              9.5.0
pip                 23.1.2
platformdirs        3.8.0
prompt-toolkit      3.0.38
psutil              5.9.5
pure-eval           0.2.2
Pygments            2.15.1
pyparsing           3.1.0
pyrealsense2        2.54.1.5217
PySocks             1.7.1
python-dateutil     2.8.2
pytz                2023.3
pywin32             306
PyYAML              6.0
pyzmq               25.1.0
requests            2.31.0
scipy               1.11.0
setuptools          56.0.0
six                 1.16.0
smmap               5.0.0
soupsieve           2.4.1
stack-data          0.6.2
sympy               1.12
texttable           1.6.7
torch               2.0.1
torchvision         0.15.2
tornado             6.3.2
tqdm                4.65.0
traitlets           5.9.0
typing_extensions   4.7.1
tzdata              2023.3
urllib3             2.0.3
wcwidth             0.2.6
widgetsnbextension  4.0.7
win32-setctime      1.1.0
xmltodict           0.13.0
xsensdeviceapi      2022.0.0
zipp                3.15.0
The full script is already posted in this topic. The error is caused by line 42 of the script in the first post. Module class is in my previous post where I declared the error. Both of them are from the OpenVINO website example linked in the first post. I commented out the few Notebook - related imports.
Hairul_Intel
Hi jvkloc,
Please ensure the location of the model folder are in the same directory as your sample script in the following configuration:
/sample_script.py
/model
--/intel
--/person-detection-0202
--/FP16
--/person-detection-0202.xml
--/person-detection-0202.bin
--/person-reidentification-retail-0287
--/FP16
--/person-reidentification-retail-0287.xml
--/person-reidentification-retail-0287.bin
Please note that the Person Tracking with OpenVINO™ code is written specifically for Jupyter Notebook and might not work correctly outside of a Jupyter Notebook environment.
I'd suggest for you to try out our Multi Camera Multi Target Python* Demo from Open Model Zoo which can also be used for person tracking and be ran directly from a terminal.
Here is the command to run the Multi Camera Multi Target Python Demo:
python multi_camera_multi_target_tracking_demo.py --m_detector person-detection-retail-0013.xml --m_reid person-reidentification-retail-0287.xml -i <input_sources> --config configs\person.py
Hairul
jvkloc
I added the extra folder (model) to the path just to be sure to get the same error. And I did get the same error. I'll try your example suggestion and post a new topic if I encounter problems with that. Thank you for your time.
Hairul_Intel
Hi jvkloc,
Feel free to open up a new question if you face any issue and we'll be happy to assist you.
This thread will no longer be monitored since we have provided information. If you need any additional information from Intel, please submit a new question.
Hairul
