Problem with installing openVino.
Vurc
I have openvino R4 on old computer but want to install R5.01 on new machine. I have tried to install it on windows 10 following all steps but i get following error when trying to start demo_squeeze_net.
3>C:\Users\t-user\Documents\Intel\OpenVINO\inference_engine_samples_2017\ZERO_CHECK.vcxproj(29,3): error MSB4019        : The imported project "C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\Common7\IDE\VC\VCTargets\        Microsoft.Cpp.Default.props" was not found. Confirm that the path in the <Import> declaration is correct, and th        at the file exists on disk.        Error
Also when I try to install it on Ubuntu 16.04 script for installing fails to download some stuff.
E: Failed to fetch http://rs.archive.ubuntu.com/ubuntu/dists/xenial/main/binary-arm64/Packages  404  Not Found
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages  404  Not Found [IP: 2001:67c:1360:8001::21 80]
E: Failed to fetch http://rs.archive.ubuntu.com/ubuntu/dists/xenial-updates/main/binary-arm64/Packages  404  Not Found
E: Failed to fetch http://rs.archive.ubuntu.com/ubuntu/dists/xenial-backports/main/binary-arm64/Packages  404  Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
Error on or near line 72; exiting with status 1
Any help would be appreciated.
om77
regarding your Ubuntu 16.04 failure, the architecture arm64 is not supported by OpenVino R5.
Shubha_R_Intel
Dear Vurc, please follow these Windows installation steps carefully :
https://software.intel.com/en-us/articles/OpenVINO-Install-Windows
And for Linux:
https://software.intel.com/en-us/articles/OpenVINO-Install-Linux
Thanks !
Shubha
